May 18, 2023 20:17:32 GMT |
a friend can't seem to find a valve shim for Saab 99 engine, if you think you can help do get in touch
69 Plymouth Fury Convertible 75 Range Rover 2 door 82 Range Rover 4 door 84 Range Rover 4 door 78 Datsun 120Y 2 door 78 Datsun 620 Pickup 81 Datsun Urvan E23 85 Datsun Vanette van 02 Electric Citroen Berlingo 76 Honda C50 07 Land Rover 130 15 Nissan E-NV200
briang
May 19, 2023 21:10:42 GMT |
Triumph based engine? try Rimmers or the likes of Burtons (lotus Twincam).
I thought they were V4
melle
South West
It'll come out in the wash.
May 20, 2023 11:52:59 GMT |
No, 95/96/97s are V4. There are two types of 99 engines, depending on model year. For early ones he can perhaps follow briang's suggestion, later ones are the same as classic 900 8V engines (not sure if they use different shims). If he has a shim but needs a thinner one, he can just sand the current one down. Glue a piece of wet and dry sandpaper onto something flat and off you go. Malbrad Saab in Huddersfield, Jamsaab in Keynsham (Bristol) or other specialists will also have shims.
Last Edit: May 20, 2023 11:57:12 GMT by melle
May 20, 2023 14:55:58 GMT |
Ah yes it is a straight engine , ex Triumph. I have passed on the info thanks.
