I have a mate with a lovely w202 c250 mercedes estate - It recently went into limp mode and is stuck in second.
I have a genuine autocom diagnostics tool with the correct 38pin adapter and I can read codes etc on the main ECU, but when it comes to the gearbox ecu - nothing. fails to connect.
The main issues are : - nothing online - diesels & petrols of pre OBD era are completely different and the tool I wanted to use, HFMscan does not work with diesels. Autocom gets further but again fails when it tries to connect to the TCU (transmission control unit)
The reset procedure appears to do nothing too - various door closes and igntion switching - still stuck in second
Does anyone know anything else I can try? - There is a unit called carsoft 7.4 but it isn't available and is a chinese copy anyway
