Just picked this FG Marder up, all surprisingly standard. Going to hunt around and see if I can get an expansion pipe that will fit with the original body.
Will have an ask around and see if there is a class running locally I can enter it in other in happy just messing about with it.
Needs a new flywheel as somebody has snapped the pull start engagement lugs on it hence starting it with the drill.
Smells lovely running castor based 2 stroke.
