86 MR2, not perfect but totally usable and ready to go.
Has some bubbling on front edge of bonnet, some bubbling on bottom of front wings (not that noticable) some small scabbings where the roof meets the windscreen.
That aside, i have totally cut out and re-welded all the major rust spots where these cars usually suffer, including both inner and outer sills towards the rear, both rear inner wheel arches and both inner rear 1/4s (have plenty of photos to prove)
I have recently replaced the clutch, rebuilt the clutch slave cylinder, replaced the water pump, fuel pump and regular service items.
The wax stat is tempremental which can sometimes hinder cold start but once started idles perfectly and is cracking to drive. The bodywork is bright and shiny with a couple of small marks but nothing major, it has a current legitamate MOT and is ready to go.
The interior is together and clean with only some heel wear on the drivers carpet. Approx 130k miles.
Any inspection welcome.
07956274704
07956274704
