Mar 29, 2023 16:26:22 GMT
I recently fitted a 1275cc MG Midget rib-case gearbox to match the engine in my Minor Traveller. It was purchased fairly cheaply, and I took a quick peek inside and all looked fairly good. However, there is a fair bit of whine and gearlever 'chatter' in 3rd gear - the other gears and synchromesh, etc. are all fine.
Does anyone have any recommendations for reducing this NVH? I was thinking along the lines of Lucas Transmission Fix or Redline 75W90, perhaps, unless there are better suggestions...
Mar 29, 2023 16:58:09 GMT
I've used redline a few times, not specifically to make a gearbox quieter, as part of routine maintenance.
It always made the gear change significantly smoother even though that's not answering your question.
Mar 29, 2023 19:39:48 GMT
75w90 is a fairly close match to the 20w50 engine oil viscosity which the books say use and it is obviously engineered for a gearbox!
I recently pulled 2 old minor boxes appart the one running on gear oil was much cleaner and showed far less wear than the one on engine oil.
Fundamently though they are not usually like that so really it needs pulling appart and investigating, re-building one is pretty straight forward and the parts are available / cheap.
Last Edit: Mar 29, 2023 19:44:27 GMT by kevins
Mar 29, 2023 20:39:22 GMT
Indeed. I was hoping for a 'cop out' solution to avoid having to remove it all again and rebuild, etc.
I do have a spare standard Minor 'box rebuilt (by myself, about 5 years ago) to hand if the worst comes to the worst, though...
bstardchild
Club RR Member Number: 71
Mar 29, 2023 21:08:13 GMT
Indeed. I was hoping for a 'cop out' solution to avoid having to remove it all again and rebuild, etc. Sawdust and thicker oil then - worked for me back in the 80's when I had a really noisy gearbox in a car that I wanted sell.......... Yeah I know not my finest hour
fulvia1436
Finally started a thread for my Fulvia life
Club RR Member Number: 63
Banana skins back in the day! 😁
'59 Austin A40, '59 VW Beetle, '63 Mk1 Cortina, '57 Austin Gypsy, '68 Fiat 850 Coupe, '68 Alfa Duetto Spider, '72 Lancia Fulvia 1.3S, '73 Lancia 2000 Sedan ie., '72 Lancia 2000 Sedan, '67 Lancia Fulvia 1.3, '83 VW Passat GL5 Estate, '81 Volvo 245 Estate, '85 Lancia Thema 8V Turbo Estate, '99 Lancia Kappa 20V Turbo Estate, '00 VW Sharan VR6, '06 Fiat Multipla 1.9 JTD, '10 Fiat Multipla 1.9 JTD, '66 Lancia Fulvia 1.3
Mar 30, 2023 13:35:30 GMT
Hi, Or Nylon stockings...hmm stockings.
Colin
Last Edit: Mar 30, 2023 13:36:10 GMT by colnerov
Mar 30, 2023 19:02:18 GMT
Disgusting Try MAZOLA vegetable oil, once oxidised it turns to a "jelly" like substance that could quieten, THUNDER.
Mar 31, 2023 22:08:43 GMT
Thanks. Similar to Universal Tractor Transmission Oil (UTTO), by the sounds of it?
Mar 31, 2023 22:43:43 GMT
The gearbox in my brother's first car was so noisy we joked about possums living in it. Was too loud to be the standard old Holden gearbox rats.
