Mar 26, 2023 19:06:29 GMT |
I must have 3-4 other build treads for cars I still haven’t finished, so might as well get something else to take up more time with, Transit mk2 LWB, which is kitted out as a mobile BBC tv licence detector van, only done 26k and is pretty well original with mostly good bodywork. 2.0 pinto, Plan is to take out what’s no use in the back, and fit a bed of some sort, table, sink and hob, along with two extra seats for the kids booster seats, these will Likely be seats out of a minibus or something with seat belts all built into them, so it’s just a case of bolting it in. Polish the body work, paint the grill and bumpers, tidy up the wheels. Service the engine, do the wiring, won’t be anything too fancy. Then hopefully use it regualary in the summer months. Just need to get it back from the auction place, as the MOT has expired, might book an MOT somehwere and drive home then cancel the MOT, or borrow a trailer, just looks a bit big for a trailer. Few pics from the auction and a couple I took.
westycapri
Club RR Member Number: 105
Mk2 Transit into camperwestycapri
@westycapri
Club Retro Rides Member 105
Mar 26, 2023 20:25:15 GMT |
This is really cool. Looks an ideal base for a camper. How's the rust on it, 26k is not a lot of miles 😀. Also becauwe it is so promenent, whats the box on the roof for?
@fantasticmrford 1984 Ford Capri 2.0s 1978 Ford Transit Autosleeper 1975 Landrover Series 111 Dormobile
This is really cool. Looks an ideal base for a camper. How's the rust on it, 26k is not a lot of miles 😀. Also becauwe it is so promenent, whats the box on the roof for? I believe they use to put the Ariel out of the from the inside to catch people with no tv licence. No real rust. Steps etc all original. One door is gone at the bottom one where arch needs a repair but overall it all good. Just need to make sure I treat it all and get some good rust protection inside doors and everywhere I can
Mar 28, 2023 17:23:29 GMT |
Many years ago I had a Lwb mk2 minibus as a daily, shudder to think what the mpg must have been, or how on earth I could afford to run it.
I remember converting from the pinto to the mk3 2.5DI and mirror tinting the windows.
Happy times
Mar 29, 2023 21:02:15 GMT |
Many years ago I had a Lwb mk2 minibus as a daily, shudder to think what the mpg must have been, or how on earth I could afford to run it. I remember converting from the pinto to the mk3 2.5DI and mirror tinting the windows. Happy times Mine averages 16mpg on LPG a little bit more on petrol. Be cheaper to fit a V8.
Many years ago I had a Lwb mk2 minibus as a daily, shudder to think what the mpg must have been, or how on earth I could afford to run it. I remember converting from the pinto to the mk3 2.5DI and mirror tinting the windows. Happy times Mine averages 16mpg on LPG a little bit more on petrol. Be cheaper to fit a V8. I’ll have to stick with the pinto for now. Guessing it just doesn’t have the guts to really pull the weight around. I’ve pick the van up now. Would anyone know where I will find the colour code for it?
Last Edit: Mar 30, 2023 9:54:44 GMT by pauly22
Mar 30, 2023 20:35:42 GMT |
I don't remember mine being particularly slow with the pinto but it definitely perked up with the Di. I only converted it as i already had a rotten mk3.
Not sure where the paint code would be. Mine was a very similar colour but I painted that and it was a vauxhal colour.
I've never been a fan of wood burners in campers but that hole in the roof almost makes it a no brainer.
Mar 30, 2023 21:12:16 GMT |
If I remember right, the pinto’s in Transits used a low compression head. Skimming the head might give it a bit more get up and go.
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
jmsheahan
Club RR Member Number: 121
Mk2 Transit into camperjmsheahan
@jmsheahan
Club Retro Rides Member 121
That's insanely cool. Look forward to seeing how this project progresses.
Mar 31, 2023 20:03:01 GMT |
Mine averages 16mpg on LPG a little bit more on petrol. Be cheaper to fit a V8. I’ll have to stick with the pinto for now. Guessing it just doesn’t have the guts to really pull the weight around. I’ve pick the van up now. Would anyone know where I will find the colour code for it? Should be on the chassis plate in the footwell, chances are it's a 2 letter code that will be from Fords commercial paint codes, mine is NG which is Cargo blue, but if you look it up on the car charts it's Nordic Green...
May 23, 2023 21:33:40 GMT |
I stuck it in for an MOT today to see what I’m dealing with, passed with no advisories. So not bad then. Will stick on a cambelt and fiddle with the timing, then I’ll tax it and run it around a bit to check everything is generally ok before pulling it apart over winter.
