Mar 23, 2023 17:09:51 GMT
That's rather a rod styled hebmüller aka the hebrod. Features a ford axle in front.
Doesn't an extender cause the same issues like a pie cut?
Or does screwing versus welding make the difference?
misteralz
Mar 23, 2023 17:57:50 GMT
Yeah, the island has ridiculous rules when it comes to mods.
Mar 24, 2023 12:13:51 GMT
Sdo I want a longer bonnet, the earlier type, how can yoh tell the difference, lots for sale that don't state the date on the listing
zeberdee
Club RR Member Number: 2
Mar 24, 2023 13:54:27 GMT
Earlier long bonnets are slightly more pointy . Pre ‘67 should be the long bonnet . Early Late
Last Edit: Mar 24, 2023 13:55:49 GMT by zeberdee
Mar 25, 2023 13:04:25 GMT
Beam extender on its way and a set of headlights
Mar 25, 2023 13:17:12 GMT
Beam extender on its way and a set of headlights you are right they are proper munster’s look good news on the beam extender had you already seen it before i messaged you??? the long bonnets are surprisingly expensive for a good clean one but they look so much better like a big tongue licking the road ha ha
Mar 25, 2023 16:00:07 GMT
Beam extender on its way and a set of headlights you are right they are proper munster’s look good news on the beam extender had you already seen it before i messaged you??? the long bonnets are surprisingly expensive for a good clean one but they look so much better like a big tongue licking the road ha ha Yes mate had msgd about it asking for measuremennts, but happy there are people out there with my build on there mind 😎 Yes deffo Munsters👻
Mar 27, 2023 17:18:48 GMT
Mar 27, 2023 18:25:24 GMT
looks like the frame head is pretty knackered
when you splitting the body from the pan ??
Mar 27, 2023 20:16:04 GMT
looks like the frame head is pretty knackered Yeah, what he said. I'd be having a proper poke around the bottom plate of the framehead, back to where the pedals fit onto the tunnel, before you get too ahead of yourself. I can see there's a chunk missing or at least bent at the front. It's pretty easy to see if the beam is bent once it's stripped a bit and resting flat on the floor.
redratbike horridoYes it's all pretty knackered, it's only going on as a mock up. I've spotted a complete floor pan/chassis etc for £450 so the plan is that at the minute, funds permitting
Mar 28, 2023 15:44:37 GMT
i started singing the munster’s theme tune in my head when i saw those ha ha
i started singing the munster’s theme tune in my head when i saw those ha ha The reaction I want, gonna be a subtle Munsters theme to it 😎
Had my first go at welding on it yesterday. Took a cut from a Toyota Landcruiser wing out of the scrap pile, cut to shape to fill in the petrol flap hole.
I'm happy with a couple of the welds. Gonna keep practicing though
Massey Ferguson crop wheels. Unlikely you would, but saw them…. £100.00 on FB Marketplace
Beam extender arrived, mojo massively broken because of what's happened to the Passat
Totally understandable, mate.
zeberdee
As above .
The mojo will return , but don’t force it .
