andyborris
Feb 28, 2023 16:00:20 GMT
Have to cut a 6 inch hole in the roof of the Landy for a vent, I have a Jigsaw, but struggle to make a decent circle in wood, let alone metal!
What's an alternative way to do this?
It's for a solar powered fan/vent to stop the dogs getting cooked!
Thanks
Last Edit: Feb 28, 2023 16:01:13 GMT by andyborris
Feb 28, 2023 16:18:13 GMT
Does it have to be round?
OGDB
Feb 28, 2023 17:01:14 GMT
Hello Andy.
You’re not a million miles away from me. I could make you up a Jig if you wanted. Hole in the middle that you could pilot and drop a bolt through as a centre point with a small slot for your jigsaw to sit, this way you could use it as a guide to get your hole? Or a series of small holes around a 6” diameter for you to chain drill and then file out?
Other than a 6” hole saw I can’t think of anything else.
Dez
Club RR Member Number: 34
Feb 28, 2023 17:36:37 GMT
If you want it perfect with no skill involved, an mdf template and a nibbler.
I could do it freehand with a grinder, but I’ve had plenty practice. Your results may differ.
Feb 28, 2023 19:01:11 GMT
It's easy to warp an unsupported panel with a jigsaw. Like dez I'd probably use a grinder or nibbler.
fulvia1436
Finally started a thread for my Fulvia life
Club RR Member Number: 63
Trepanning tool will do it if you're careful
'59 Austin A40, '59 VW Beetle, '63 Mk1 Cortina, '57 Austin Gypsy, '68 Fiat 850 Coupe, '68 Alfa Duetto Spider, '72 Lancia Fulvia 1.3S, '73 Lancia 2000 Sedan ie., '72 Lancia 2000 Sedan, '67 Lancia Fulvia 1.3, '83 VW Passat GL5 Estate, '81 Volvo 245 Estate, '85 Lancia Thema 8V Turbo Estate, '99 Lancia Kappa 20V Turbo Estate, '00 VW Sharan VR6, '06 Fiat Multipla 1.9 JTD, '10 Fiat Multipla 1.9 JTD, '66 Lancia Fulvia 1.3
jimi
I'd be extremely careful using a 6" holesaw on sheetmetal, it can be vicious if it grips, will twist your arms off depending on the torque of the drill. Last time I did it it took two of us to hold the drill. That was on metal wall panels (sandwich of sheetmetal - fibreglass insulation - sheetmetal) 😉
andyborris
Thanks everyone. Think I'll try a hole saw, but with 2 pieces of ply sandwiching the hole to stop it vibrating.
I'll second the advice on hole saws snatching, I ended up in the local urgent care centre after an incident with a 4" masonry hole cutter.
Drilling a lot of small holes, big enough for Your (electric) jigsaw blade to fit through, close to the edge of Your 6 inch hole, then jigsawing away the inner part, after that filing or grinding away the rest?
v8ian
bricol
Mar 10, 2023 14:20:48 GMT
Aroof skin, assuming any stiffeners are well away, should be easily cuttable with a pair of suitable snips - draw your circle, drill hole(s) to get snips in, and start cutting carefully . . .
