Feb 21, 2023 14:00:22 GMT |
Apologies if this has been covered before but I'm new to this. I think I read somewhere that where parts are not available to keep an old vehicle on the road, that you could replace them with a similar modern equivalent and not be penalised under the points system, also not applicable if you were improving the safety at the same time... is this true? I have a 1959 Bedford CA van and the front suspension is knackered - parts are not generally available apart from bearings etc so my idea would be to replace the whole subframe assembly with one from an MGB. The MGB is a similar subframe assembly with wishbones etc but would come with disc brakes and rack and pinion steering thereby improving safety at the same time. How would such a 'repair' be looked at, would it affect the vehicle under the points system or not?
Feb 21, 2023 15:13:56 GMT |
Hi, It would, because you have changed two qualifying items/categories (axles and steering), two points each so four in total. You mustn't go below eight points.
Colin
Feb 21, 2023 15:54:52 GMT |
So, there is no 'amnesty' for unobtainable original spares? This will be one stealthy way of getting classics off the road then as, when parts are no longer available, the vehicles cannot be realistically be repaired!
zeberdee
Club RR Member Number: 2
Feb 21, 2023 16:22:46 GMT |
Taken from the gov.uk website www.gov.uk/government/publications/historic-classic-vehicles-mot-exemption-criteria/historic-classic-vehicles-mot-exemption-criteriaAcceptable changes It does not count as a ‘substantial change’ if: changes are made to preserve a vehicle because the original type parts are no longer reasonably available they are changes of a type which can be demonstrated to have been made when vehicles of the type were in production or within 10 years of the end of production axles and running gear have been changed to improve efficiency, safety or environmental performance changes were made to vehicles that were previously used as commercial vehicles, and you can prove the changes were made when the vehicle was used commercially
Last Edit: Feb 21, 2023 16:46:26 GMT by zeberdee
zeberdee
Feb 21, 2023 16:26:04 GMT |
Pretty sure this topic has been covered before .
You can read the rules in a number of ways & there’s vehicles out there that are definitely pushing the boundaries .
Feb 21, 2023 16:28:39 GMT |
Hi, Not necessarily, You could try speaking to DVLA/DVSA and explaining and see if they would be amenable to a substitution on a case by case basis. However don't go cutting the chassis rail about to fit it.
Colin
Edit: Beaten to it and better explained.
Last Edit: Feb 21, 2023 16:30:46 GMT by colnerov
Feb 21, 2023 18:12:21 GMT |
It would be a substantial change and therefore need an MOT as it would lose its exemption. No biggy. It would still have eight points so no iva (if, as said, the monocoque is not modified).
Proton Jumbuck-deceased :-( 2005 Kia Sorento the parts hauling heap V8 Humber Hawk 1948 Standard12 pickup 1953 Pop build (wifey's BIVA build).
Dez
Club RR Member Number: 34
Feb 21, 2023 18:31:45 GMT |
Modify the new subframe so it bolts on to the factory mounts on the chassis, and don’t bother telling them. No one will really care and if anyone ever does, point to the exemption on parts availability.
It’s one of those instances where trying to do ‘the right thing’ will only cause you grief.
Feb 21, 2023 20:19:48 GMT |
All good info thanks. If I go this way, I would modify the subframe to mount on the original Bedford mounts so it would be reversible. I would get it MOT'd as a matter of course and inform my insurance company, but they have already said they wouldn't penalise mods that enhance safety eg. disc brakes. I guess it may become more complicated if I wanted/needed to do something about the engine/gearbox further down the line.
tofufi
South West
Taken from the gov.uk website www.gov.uk/government/publications/historic-classic-vehicles-mot-exemption-criteria/historic-classic-vehicles-mot-exemption-criteriaAcceptable changes It does not count as a ‘substantial change’ if: changes are made to preserve a vehicle because the original type parts are no longer reasonably available they are changes of a type which can be demonstrated to have been made when vehicles of the type were in production or within 10 years of the end of production axles and running gear have been changed to improve efficiency, safety or environmental performance changes were made to vehicles that were previously used as commercial vehicles, and you can prove the changes were made when the vehicle was used commercially Just to throw a bit of confusion into the ring... All of the above relates to MOT exemption. The term 'substantial change' is used, whereas for vehicle identity the term 'radically altered' is used. My understanding is that the 8-point rule for vehicle identity is stand-alone from the MOT exemption rules, and doesn't make any allowance for parts being unavailable. Of course, on a standard car with a new front axle (and unmodified monocoque) you'd still have 8+ points overall, so it would be able to retain the original ID.
zeberdee
Welcome to the world of government & vehicles . Nothing makes sense when you dig down into it .
Try being an MoT tester & working out what they mean & how they even came up with the wording .
I think all of it is written by someone that doesn’t understand motor vehicles & possibly doesn’t even drive .
tofufi
South West
Welcome to the world of government & vehicles . Nothing makes sense when you dig down into it . Try being an MoT tester & working out what they mean & how they even came up with the wording . Try working for DfT and understanding the UNECE and GB adopted (formerly EU) type approval legislation for new vehicles  I suspect that at a point in time, someone decided that there should be a way to define when a vehicle is no longer considered to be the original vehicle. At another point in time, someone decided some vehicles should be MOT exempt, but not if they're substantially modified. Someone probably wrote some rules, taking no heed (or being unaware) of the similar ones for something else.
Last Edit: Feb 22, 2023 9:23:46 GMT by tofufi
Feb 22, 2023 10:23:34 GMT |
The points for changing "axles" (which inexplicably count as one thing front and rear) and "suspension" (also front and rear) are just total BS when it comes to something like a VW Beetle, where the suspension is part of the "axles" and so is the gearbox. I guess that axles and suspension rule might fit a Model T ford or similar, with distinct axles and springs, but where's the front "axle" on a mac strut suspended car like an old Escort? A front crossmember is not an axle. Such a useless one size fits all (except it really doesn't) system.
Feb 22, 2023 10:46:07 GMT |
Now not that I'm condoning this, but there's an element of enforceability here. How the hell is anyone going to find out? It's MoT exempt (and MoT testers don't get trained/paid/expected to enforce these rules), and a policeman at a traffic stop (or even an insurance inspector) isn't going to know a 1959 Bedford subframe from an MGB one. It's a nonsensical system without even the slightest consideration made to its practical application, and stupid rules poorly applied should be treated as stupid rules poorly applied. Maybe I am condoning it!
Last Edit: Feb 22, 2023 10:47:16 GMT by biturbo228
Feb 22, 2023 11:08:55 GMT |
Now not that I'm condoning this, but there's an element of enforceability here. How the hell is anyone going to find out? It's MoT exempt (and MoT testers don't get trained/paid/expected to enforce these rules), and a policeman at a traffic stop (or even an insurance inspector) isn't going to know a 1959 Bedford subframe from an MGB one. It's a nonsensical system without even the slightest consideration made to its practical application, and stupid rules poorly applied should be treated as stupid rules poorly applied. Maybe I am condoning it!  I'd agree. If it's a broadly like for like swap of parts, then who's going to know, or care? One live axle looks al lot like another, as do subframes. Also seems rubbish that on one hand there's no obligation to test the car (assuming it's MOT exempt), presumably based on the fact that MOT testers might not be clued up enough on every old car to test correctly, yet on the other there's a huge list of things you can't do. So which is it? Exempt from being looked at, or not?
Last Edit: Feb 22, 2023 11:09:33 GMT by horrido
Feb 22, 2023 12:10:49 GMT |
I'd agree, you are only ever going to get in trouble if it breaks causing an accident, make a good job of it and properly maintain it and you'll be fine.
Feb 22, 2023 13:56:20 GMT |
Hi, Over the years I've come to the conclusion that, with a variety of subjects, about all these rules/regulations/protocols that they don't really care what we do, however if it all goes wrong the rules are in place to deal it or punish. So if we are sensible it shouldn't be a problem.
Colin
Not saying this is the case here but legislators / enforcers often create accounts on forums to ask questions like this to see what people in the car world do in reality with the rules. I wouldn't condone or advise on ways around legislation on an open forum. That being said, there are quotations above from the official texts stating what is required in the original post would be legal anyway so no laws would be broken in this case.
You get similar questions about insurance from people who've only just joined to try and find out how people get insurance discounts or make claims in ways insurers would not be happy with.
You would not get in trouble personally for things you say but bear in mind that talking in a casual carefree manner about whether or not you could get caught for breaking certain rules on a public forum cannot possibly be helpful to classic car owners generally if the wrong (anti-car) people get to read what you've said!
Last Edit: Feb 23, 2023 9:59:57 GMT by ejenner
Feb 28, 2023 11:37:52 GMT |
Hi it will work sort of the wheels are to small you cant get the rack to fit use the steering box and the springs are far to weak you have the whate of 2 people over the wheels you will need new front springs look at your springs and you will see that they have a much bigger diameter that the MGB I can tell you all this cos I have done this if you want a look PM me
