Feb 13, 2023 15:34:41 GMT |
I'm fitting a new cylinder head to a Mini engine. The head is coming from a complete engine with pushrods, rocker gear etc. The engine it's going on also has its original pushrods
I'm wondering if I should use the ones coming with the head or the existing ones sat in the block?
Feb 13, 2023 16:33:00 GMT |
I'm fitting a new cylinder head to a Mini engine. The head is coming from a complete engine with pushrods, rocker gear etc. The engine it's going on also has its original pushrods I'm wondering if I should use the ones coming with the head or the existing ones sat in the block? Use the eight straightest least worn pushrods.
slater
Club RR Member Number: 78
Feb 13, 2023 16:34:01 GMT |
Yeh doesn't really matter.
Feb 13, 2023 16:53:04 GMT |
Great
Thank you 👍
