Looking to possibly swap or PX this for something kitcar shaped (Dutton, Sylva, Spartan etc etc)
1963 Chrysler 300 2dr
413RB 6.8ltr V8 w/torqueflite pushbutton 3sp Auto
Sat on 15/7fr & 15/10rr steel wheels with babymoon centre caps
Engine has recently had a freshen up with new rings & bearings and is also now fitted with the following:
Edelbrock E-street aluminium cylinder heads
Edelbrock RPM intake manifold & currently 800cfm carburettor
Comp-cams XE268H camshaft & double-roller timing chain set
New gaskets & core plugs
Mopar electronic ignition system
High-torque starter motor
Aluminium radiator
New water pump
New mechanical fuel pump
Exhaust is a 3/4 length setup I fabbed up in 2.5" diameter with a pair of stainless silencers and turn downs just after rear axle, sounds lovely as is but would be better finished to full length in my opinion(was on the list for eventually)
Exterior is tidy from afar but is beginning to show its age, previously the outside at least was restored/resprayed Black in the 90's with silver painted bumpers but originally White w/chrome bumpers when new
Interior is beige vinyl w/white headlining and grey carpet, aside from the front centre seat having a crack in the base and door cards getting a bit tired its a lovely place to be. Sunpro tach fitted to steering column, aftermarket oil pressure & vacuum gauges on lower dash and a bluetooth amplifier in the glovebox powering a pair of 6x9's under the rear parcel shelf
Brakes all stop as they should bar a bit of judder under heavy braking which I believe is down to warped drums which will need sorting soon and
Overall the car is far FAR away from a perfect example and does need lots of little jobs doing BUT its a driver and the vast amount of those jobs can be done bit by bit whilst still using it.
Off the top of my head the most needed jobs I can think of are:
Heater needs plumbing back in(was told it leaks, never found out where from)
Wipers need attention (passenger spindle needs rethreading & drivers arm a new spring)
No washer bottle or pump currently
Door seals all round
Door shuts, underside of bonnet and bootlid need painting
Not looking for a straight up sale if possible, swap or PX please
Any questions please don't hesitate to ask
Thanks
