Hello
need an s tye manual flywheel and manual flywheel bolts x6
need the sandwich or blockplate
need a manual starter - if the auto is different, have a new one but i think it was for the auto engine i bought
need the friction disc - its not ford 23 splines it getrag
need the pressure plate and all the shouldered bolts
need the rubber do nut bolts and nuts
need the rear part of the prop shaft, with the bearing
need a thermostat housing.
oh and a clutch slave cylinder and the flexi
and the gear stick
and the thermostat housing - i have th etop part
and the gear stick
