Need a little advice here chaps.
Woody has been converted from rod based clutch control to a hydraulic system to match the new gearbox set up.
Challenge is that the only place that I can fit the master cylinder dictates that there will need to be a 60mm spacer from the pedal to the MC rod. If I had a lathe etc..but I don't. any ideas where I can get a drilled bit of bar stock so that I can make uo the spacer?
Done the usual search online but not really found what I am looking for.
Thanks,
P.
Thanks,
P.
