Sammo
Club RR Member Number: 103
What a lovely little car! As and when the engine swap happens I'd be interested in the original engine and box to upgrade the better halfs auto Mini. I've got plenty of manual 1275 bits around including cranks, rods etc if you need anything / fancy a trade. Cheers James I will let you know once the engine is out. Won't be for a little while yet though. Typically I've already ordered a crank and rods which arrived today.
Follow Me On Instagram - @parttimecartinkerer
Sammo
When I agreed to buy the Metro the seller mentioned that it needs a new choke cable. Easy fix so not a problem at all, except the choke cables are a nightmare to get in the correct length! So far I've ordered two different cables which haven't fitted. There's another one on its way to me now which I believe is correct! Fingers crossed. In other news, my hydralastic pump has arrived so I can raise the suspension a little I've also contacted the local graphics company and asked if they can make me another side sticker to match the one on the passenger side. It's not an original Metro graphic but I think it suits the car and want it on both sides!
Sammo
Nov 13, 2022 12:32:26 GMT
Popped down to Dorset this morning to pick these up. They’re from a Mk2 Suzuki Swift GTi. In really good condition and they were cheap! Just need to get the rails changed and they’ll be going in
ovimor
North East
...It'll be ME!
Nov 13, 2022 12:42:00 GMT
+1 Vote.... For a Swifty 😉
Lovely truck to bimble about in, you have 👍
OVIMOR
Last Edit: Nov 13, 2022 12:42:19 GMT by ovimor
Knowledge is to know a Tomato is a 'fruit' - Wisdom, on the other hand, is knowing not to put it in a 'fruit salad'!
Sammo
Dec 28, 2022 13:27:11 GMT
Sammo
Dec 28, 2022 13:36:24 GMT
My insurance renewal email came through this morning and surprise, surprise it had gone up by £100! Fifteen minutes spent on the various comparison sites and I'd managed to get another years insurance for £98. I also bought it through Topcashback so I'll be getting a £43 rebate from them I'm not going to complain at paying £55 for a years insurance!
Sammo
A long overdue update. I lost my job in January so all plans were put on hold. I’ve managed to get an interim job driving a recovery truck for pretty much minimum wage and I’m in the process of getting my HGV licence but that won’t be for a few months yet. All this has meant I’ve had to scale back my plans for the little Metro as I don’t know when I’m going to have a decent amount of money coming in again. The bike head conversion will have to wait. I’ve got the spare block stored in the garage so that can be done one day. I’ve found someone locally that can modify the auto block to convert it to manual. He’s done hundreds of them for his race cars so I’m happy he knows what he’s doing. While the engine is out I’m replacing the various bearings to freshen it all up and I’m going to chuck a Swiftune cam in there to liven it up a bit too. Along with the manual gearbox and a slightly larger carb’ this should make it much more fun to drive. I need to sell my F56 Cooper S as I can no longer afford the monthly payments or fuel in that so in preparation for finally using the Metro as a daily I decided to sort the cooling system out. When I drove the car to the Brooklands New Years Day Gathering it was getting a bit warm going along the A3. I decided to replace the water pump, thermostat and flush the cooling system through as well. This is what I was greeted with this morning. The curse word weather the other day had blown the cover off the car. I got straight on and removed the front fog lamps. I haven’t been a fan of them since I bought the car. The bumper isn’t great under the brackets but I can get another one at some point. Then the front panel came off and I started draining the coolant. I say coolant, it was more of a pinky rusty colour that came out. Once the rad, alternator and coolant hoses were all off I got on with removing the thermostat and water pump. The pump didn’t look very old at all but I’d already bought a replacement so it was getting used. Annoyingly the only replacement I could find was one with a water bypass pipe. These aren’t used in the Metro so I tapped the hole and thread locked a bolt in there along with some silicone for good measure. Hopefully it doesn’t leak!! With that done I bolted the new pump in and reattached everything. It started raining at this point so this is the last photo I took! The front panel went back on but I’ve left the Rover grill off. I’ve got the proper Austin one to go on so I’ll give that a clean up and then fit it. I also realised I didn’t have any coolant so I’ll need to pop to the motor factors and get some during the week. Once it’s filled up I can drive it to work one day and see how the coolant temp is looking. Nothing was blocked when I flushed it so hopefully it was just a knackered thermostat causing the car to get hot. Oh, I also found a nice puddle of water in the passenger footwells when I looked in there earlier. Looks like it’s coming through the passenger rear window seal so I’ll need to order a new seal for that. Not the end of the world. I think I’ll do the other side while I’m at it too!
Sammo
Apr 16, 2023 19:41:40 GMT
Filled the engine with coolant today. Good news, no leaks and the temp is now staying slap bang in the middle of the gauge Also fitted a steering wheel that I’ve had kicking around for ages. Much nicer to use than the standard bus wheel! [a href=" |https://thumbsnap.com/eTZVsnGb"] |https://thumbsnap.com/eTZVsnGb[/a] The engine is still running like a sack of curse word though so it’s going to a local Mini specialist on Wednesday for a tune up. The car is now officially being used as my daily so it better behave!
Apr 16, 2023 21:17:06 GMT
Interesting; we have a Motamec trolley jack at work - I didn't know they do steering wheels also! Certainly looks very smart.
Sammo
Apr 16, 2023 21:33:19 GMT
Interesting; we have a Motamec trolley jack at work - I didn't know they do steering wheels also! Certainly looks very smart. Motamec is MST Cars. They do all this sort of thing. I’ve got their wheels in a couple of my cars. Always good quality etc.
Apr 16, 2023 21:34:45 GMT
How did you get a specific boss to fit the Metro?
Sammo
Apr 16, 2023 21:55:01 GMT
How did you get a specific boss to fit the Metro? I used a Mini boss. Same spline pattern.
Sammo
Apr 17, 2023 22:35:08 GMT
Another quick update.
I decided to take the Metro to work today. It still isn’t running right but it made it there with no dramas. On the way home I had to jump on the A3 to go and get dog food. It started getting quite hot on the way there and then on the way back it started boiling over! The section of A3 I was on has nowhere to pull over so I had to just keep going. The engine was rattling its poor little head off by the time I got off the A3. By that point I figured whatever damage is done is done so I carried on the extra five minutes home with it rattling and steaming away frown I got home and couldn’t get the bonnet open so it’s been abandoned outside the house for now.
Absolutely no idea what to check next as I’ve flushed the cooling system, replaced the water pump and thermostat and checked the fan is working.
zeberdee
Club RR Member Number: 2
Check the ignition timing , if that’s out it can course overheating . Also if it’s running weak will also course .
Also best to carry out a compression test after such an episode; a healthy A-series should have at least 170psi or so on each cylinder.
Sammo
Apr 18, 2023 11:55:12 GMT
I won’t be able to look at the car until the weekend now but I think this has just sped up the process of pulling the engine to convert it to manual.
spacekadett
F*cking take that Hans Brrix!!
Apr 18, 2023 12:31:43 GMT
I won’t be able to look at the car until the weekend now but I think this has just sped up the process of pulling the engine to convert it to manual. I wouldn’t write it off until you’ve had a quick look at it. Back in the day I drove my daily Mk1 literally until it rattled to a stop ( thermostat had stuck and I was too busy talking to my brother to notice the temperature gauge was pinned to the top stop 😂). Let it cool down and refilled it with water and it drove home fine and with a new thermostat it never missed a beat afterwards. Assuming it does run again I also reckon it’s worth checking timing and for lean mixture/ air leaks as culprits for why it overheated, along with checking the fan and making sure the radiator is hot all over and not partially blocked
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
Nath
Looking for a Retro
Love an old Metro! shame about those holes where the spot lights used to be, hopefully you can get a new bumper. Gutted you're changing to manual and the steering wheel but i think we have different ideas lol. Bookmarked.
Sammo
Apr 19, 2023 13:29:30 GMT
Love an old Metro! shame about those holes where the spot lights used to be, hopefully you can get a new bumper. Gutted you're changing to manual and the steering wheel but i think we have different ideas lol. Bookmarked. Haha the auto gearbox is terrible so I can’t wait for it to go! Also the original wheel wasn’t nice to use at all. Too big and with the steering wheel being offset from the drivers seat it just felt awkward to steer.
Nath
Looking for a Retro
Apr 20, 2023 12:39:31 GMT
The steering is offset? I never knew that.
I keep coming across a post on Facebook someone selling a load of badges of all kinds, want me to look out for any for you?
