alexr8
Let's do this!
Sept 16, 2022 19:37:02 GMT
People have been fitting transaxles upside down (relocating the drain plug) or opening them to flip their internals.
I wonder if making the engine turn the other way is a feasible alternative. I can't seem to think of it requiring any more (or less) than a custom (reversed) camshaft and a starting motor that turns the other way. I must surely be missing something here.
Comments?
Last Edit: Sept 16, 2022 19:46:50 GMT by alexr8
Rich
Club RR Member Number: 160
Sept 16, 2022 23:55:05 GMT
Oil pump, belt or chain tensioning being on the wrong side of the run, distributor bob weights, water pump, to name but a few issues. But it’s feasible if you were to overcome those kind of things I suppose.
alexr8
Let's do this!
Sept 17, 2022 17:03:06 GMT
Oil pump, belt or chain tensioning being on the wrong side of the run, distributor bob weights, water pump, to name but a few issues. But it’s feasible if you were to overcome those kind of things I suppose. Oh, I see it involves plenty more than I had thought. Thanks a lot, I was really curious.
Sept 17, 2022 19:59:13 GMT
You should habe a look on some of the fiat 850 tuning/engine swap threads. The 100 series 903cc can be found in factory trim spinning in both directions so swaps are common.
alexr8
Let's do this!
Sept 17, 2022 22:07:05 GMT
You should habe a look on some of the fiat 850 tuning/engine swap threads. The 100 series 903cc can be found in factory trim spinning in both directions so swaps are common. Wow, awesome, thanks!!
