Aug 21, 2022 17:35:20 GMT
Hi Folks
My father in law is trying to find a OSF door seal for his 2007 Vauxhall Signum part number V0013149762. So far we are drawing a blank - any pointers for obsolete Vauxhall parts?
cheers folks
Cortinaman
Old Fords never die they just go sideways
Aug 21, 2022 20:52:18 GMT
You sure that numbers correct? It doesn't go into my system at all.
Could it be: 13149755
13149762 is a good part number but thats for the nearside/passenger side door, the drivers side door seal is 13149763 also used on Vectra C models so there must be loads of those in the scrappers, nothing I have in stock unfortunately
I do have 13149755 which was used up to 2005 but its not flock coated
13149762 is a good part number but thats for the nearside/passenger side door, the drivers side door seal is 13149763 also used on Vectra C models so there must be loads of those in the scrappers, nothing I have in stock unfortunately I do have 13149755 which was used up to 2005 but its not flock coated thanks for that - could have saved an expensive mistake! How much do you want for the 13149755 (feel free to PM me) as I don't think my FIL is going to be too bothered if its flocked or not! cheers Cortinaman PS FIL has asked what glue to use to stick it on - I am guessing a high temperature glue would work?
Aug 22, 2022 10:10:29 GMT
Here you go, it just knocks on to the body flange of the door opening so no glue required, for some reason the flocked version is handed but the plain black ones can be used on either front door, just sent you a PM
Last Edit: Aug 22, 2022 10:14:57 GMT by gtviva
Aug 22, 2022 11:39:51 GMT
cheers gtviva I guess the flocking would be on the inside so their would need to be handed versions? hopefully FIL will be in touch to buy it off you shortly Cortinaman
