Fair-to-good condition with a few scratches and marks but nothing major. Look good from a few feet away.
Not sure what brand these are but the quality seems reasonable.
These are Ford-fit, with a 63mm centre bore and a fairly high negative offset. I think they were on a MK3 Fiesta once upon a time.
However, I also have a set of 15mm hubcentric spacers machined to allow them to fit a PSA car with the 65mm centre bore on the hub side and the Ford size spigot on the wheel side, along with a set of longer M12x1.25mm wheel bolts. These are available for an extra £50, with first refusal going to the buyer of the wheels.
I had them on my Citroen ZX hence the centre caps. You could easily swap those or put a sticker on for a Ford or a Peugeot.
The tyres are 165/70R13 Toyo Nanoenergy, fitted in 2021 and with less than 5000 miles on them. Balanced well, didn't have a shake at speed. Date codes of 48th week 2020.
