Tony - East London
Based in Essex / East London doing up a Cortina MK3 3.0 V6 XLE from South Africa
Jul 16, 2022 21:28:59 GMT
Hello Chaps, I need your help please!! I have a imported 1975 MK3 Cortina which is a standard 3.0 V6 XLE from South Africa. One of my front springs has snapped so I need to replace them. Does anyone know an aftermarket make or replacements I can use? Perhaps Capri/ Granda may fit? I need someone who knows what they are talking about. Also the front brakes have failed, a clip/bracket has broken. See pictures to give an idea. Any help would be appreciated. Many thanks. Tony
Help - Front springs Mercdan68
@forddan68
Club Retro Rides Member 68
Jul 16, 2022 22:49:49 GMT
Try burton power products for the springs
Fraud owners club member 2003 W211 Mercedes E class 1989 Sierra sapphire 1998 ex bt fiesta van
Tony - East London
Jul 18, 2022 12:03:15 GMT
Try burton power products for the springs Burtons no good?? Because my car is not a UK model they don’t have any comparison info to help??
Jul 18, 2022 14:02:10 GMT
We never got 3.0l Cortinas, so there isn't a direct comparison.
We did get 2.3 Cortinas, which use a similar V6. I doubt you'll notice a difference if you use springs intended for one of those.
Personally I found that I never spent enough for Burtons to be interested in giving any advice, all they wanted was the £200 in the till and me somewhere else.
@forddan68
Jul 18, 2022 18:53:23 GMT
We never got 3.0l Cortinas, so there isn't a direct comparison. We did get 2.3 Cortinas, which use a similar V6. I doubt you'll notice a difference if you use springs intended for one of those. Personally I found that I never spent enough for Burtons to be interested in giving any advice, all they wanted was the £200 in the till and me somewhere else. Never had one problem with burton since the 1980s If not go direct to bilstein
Tony - East London
Jul 18, 2022 19:33:18 GMT
We never got 3.0l Cortinas, so there isn't a direct comparison. We did get 2.3 Cortinas, which use a similar V6. I doubt you'll notice a difference if you use springs intended for one of those. Personally I found that I never spent enough for Burtons to be interested in giving any advice, all they wanted was the £200 in the till and me somewhere else. Yes, got that impression too!!
Tony - East London
Jul 18, 2022 19:39:14 GMT
We never got 3.0l Cortinas, so there isn't a direct comparison. We did get 2.3 Cortinas, which use a similar V6. I doubt you'll notice a difference if you use springs intended for one of those. Personally I found that I never spent enough for Burtons to be interested in giving any advice, all they wanted was the £200 in the till and me somewhere else. Another group said the 2.3 would not be strong enough and would t sit right? Really no idea on this. Coil Springs say they can make a pair if I send one to them for the pattern. Expensive alternative, may have no other choice!!
Jul 18, 2022 21:07:31 GMT
We never got 3.0l Cortinas, so there isn't a direct comparison. We did get 2.3 Cortinas, which use a similar V6. I doubt you'll notice a difference if you use springs intended for one of those. Personally I found that I never spent enough for Burtons to be interested in giving any advice, all they wanted was the £200 in the till and me somewhere else. Another group said the 2.3 would not be strong enough and would t sit right? Really no idea on this. Coil Springs say they can make a pair if I send one to them for the pattern. Expensive alternative, may have no other choice!! a 3.0l Essex is heavier than a 2.3 Cologne. But not by enough to matter unless you're an F1 testdriver intending to put the Cortina on the front row of the grid. I would be seriously considering something like this LINK
Tony - East London
Jul 18, 2022 21:49:50 GMT
The link just shows the following info:-
Cortina 4/5 V6 Front [RD1007]
Front or Rear: F
Lbs or % Uprated: 275
Lowered (mm)
-3'': -2'': -1'': 12 Std. Ride: 13.0 +1'':
Priced each.
£22.50
Don’t make sense to me?? Are they the springs I need, or at least an alternative? Only driving and enjoying the car - no rally or thrashing it. More like Mrs Daisy lol
Jul 18, 2022 21:53:33 GMT
The photo is a bit close in to tell the type of caliper, but UK Cortinas had Girling type 16s. I would think that the bottom leg of the anti-rattle spring should be behind the pad pin like it is at the top. Also it looks like the r-clip is missing from the top pad pin - I'm fairly sure I can see an empty hole - I wonder if the strange looking clip you show was someone's attempt at a temporary fix.
'57 Austin Cambridge A55 1800 Overdrive '50 MG Y-type (In build) '56 Standard Super 10 (In build) '04 Seat Leon TDi 130 (Wet weather runabout) '03 Citroen Berlingo HDi (Parts hauler)
Jul 18, 2022 22:43:53 GMT
Are Falcon springs a valid option? I believe the Australian 3.3 and 4.1 litre inline six Cortinas used most of the same front suspension componentry as their six cylinder Falcon stablemates.
Tony - East London
The photo is a bit close in to tell the type of caliper, but UK Cortinas had Girling type 16s. I would think that the bottom leg of the anti-rattle spring should be behind the pad pin like it is at the top. Also it looks like the r-clip is missing from the top pad pin - I'm fairly sure I can see an empty hole - I wonder if the strange looking clip you show was someone's attempt at a temporary fix. So the clip thing may not be the original piece? As it’s a 3.0 would the front brakes be bigger than the normal 2.0 like the rear shoes?
Tony - East London
Are Falcon springs a valid option? I believe the Australian 3.3 and 4.1 litre inline six Cortinas used most of the same front suspension componentry as their six cylinder Falcon stablemates. Igor - thanks but I haven’t a clue mate? As a novice this is proving very difficult to resolve !!
Jul 19, 2022 10:22:41 GMT
So the clip thing may not be the original piece? As it’s a 3.0 would the front brakes be bigger than the normal 2.0 like the rear shoes? Possibly to both, I have no experience of genuine 3.0 Cortinas as we didn't get them. Is there a similar piece on the other side caliper?
Darkspeed
Club RR Member Number: 39
Help - Front springs Darkspeed
@darkspeed
Club Retro Rides Member 39
Jul 19, 2022 11:34:54 GMT
I would fit some standard length 2.3 MK4 Cortina springs - as Nick has suggested. Even if they are not right - every chance that they will be good enough based on your indicated requirements - at least you will then have a datum on which to work forward from. Or you do it scientifically - remove a good spring - count the coils - measure the free length and the wire diameter or just send to a specialist to copy = Typically about £80 each if they cannot match it from stock As mentioned brake pin looks like it has just not been fitted correctly. How many wheels studs in the hubs ?
Jul 19, 2022 12:24:11 GMT
The link just shows the following info:- Cortina 4/5 V6 Front [RD1007] Front or Rear: F Lbs or % Uprated: 275 Lowered (mm) -3'': -2'': -1'': 12 Std. Ride: 13.0 +1'': Priced each. £22.50 Don’t make sense to me?? Are they the springs I need, or at least an alternative? Only driving and enjoying the car - no rally or thrashing it. More like Mrs Daisy lol It doesn't look confusing to me: it lists 5 springs rated at 275lb/in(probably a small upgrade over stock), which will provide stock, lowered or raised ride heights when used on a V6 Cortina. You decide whether you want stock, 2"(or whatever) lowered and order two of those springs. It's only a Cortina, and those are still common enough for this sort of part to be relatively easy to source.
Tony - East London
Jul 19, 2022 12:34:37 GMT
The link just shows the following info:- Cortina 4/5 V6 Front [RD1007] Front or Rear: F Lbs or % Uprated: 275 Lowered (mm) -3'': -2'': -1'': 12 Std. Ride: 13.0 +1'': Priced each. £22.50 Don’t make sense to me?? Are they the springs I need, or at least an alternative? Only driving and enjoying the car - no rally or thrashing it. More like Mrs Daisy lol It doesn't look confusing to me: it lists 5 springs rated at 275lb/in(probably a small upgrade over stock), which will provide stock, lowered or raised ride heights when used on a V6 Cortina. You decide whether you want stock, 2"(or whatever) lowered and order two of those springs. It's only a Cortina, and those are still common enough for this sort of part to be relatively easy to source. Was told mine should be 340lbs/in which would suggest 275 is well short??
Tony - East London
Jul 19, 2022 12:35:35 GMT
I would fit some standard length 2.3 MK4 Cortina springs - as Nick has suggested. Even if they are not right - every chance that they will be good enough based on your indicated requirements - at least you will then have a datum on which to work forward from. Or you do it scientifically - remove a good spring - count the coils - measure the free length and the wire diameter or just send to a specialist to copy = Typically about £80 each if they cannot match it from stock As mentioned brake pin looks like it has just not been fitted correctly. How many wheels studs in the hubs ? Normal 4 stud
Tony - East London
Jul 19, 2022 12:37:10 GMT
So the clip thing may not be the original piece? As it’s a 3.0 would the front brakes be bigger than the normal 2.0 like the rear shoes? Possibly to both, I have no experience of genuine 3.0 Cortinas as we didn't get them. Is there a similar piece on the other side caliper? Not sure, suppose a strip down of both sides is needed. Can send spring off to be made and revamp brakes. Where’s me manual 😎
Darkspeed
@darkspeed
Jul 19, 2022 13:00:51 GMT
Just wondering if they had been raiding the Granada parts bin. For custom springs / springs copied from existing Faukner will do it and so will SpringcoilETA With the 340# reference you are adding information not given in the original post ! This makes it difficult to give valid advice if you already know what they should be!! If they are 340# springs then just remove the good one to get the OD and the free length and just order one from any spring supplier - or two as best replaced in pairs - However if not 100% certain they are 340# send yours to them.
Last Edit: Jul 19, 2022 13:07:27 GMT by Darkspeed
