Jun 15, 2022 12:37:50 GMT |
I'm looking for help and advice with an issue with heat soak and carburettor angle. I wonder if anyone has knowledge of a material that will insulate the carburettor from the inlet manifold and is easily machined. I have an issue where the angle of the carb needs to be changed a few degrees as it runs dry when accelerating up an incline and suffers with vapour lock on occasion when trying to start. Here's a couple of pics showing that the likelihood of purchasing something of the shelf if pretty remote. Thanks for your help.
zeberdee
Club RR Member Number: 2
Carburettor issueszeberdee
@zeberdee
Club Retro Rides Member 2
Jun 15, 2022 13:16:22 GMT |
Some aluminium sheet with reflective gold tape on the underside would be a quick & cheap solution .
goldnrust
West Midlands
Minimalist
Jun 15, 2022 13:24:43 GMT |
The carb should not run dry over being off angle by a few degrees? In theory I could see that the float might sit a little high or low, but it shouldn't run dry... That seems more likely to be a fuel flow issue, as long uphill stretches, outside of track use, are probably when you'd use the most prolonged large throttle openings and therefore fuel use. Are the filters clean, and the pump up to the job?
Is the gasket that seals the float level when the carb is fitted to the car? This is normally a good indicator of the angle the carb was intended to be mounted at.
I can't help with the right material to insult the carb to avoid heat soak. Though, if the car is running lean due to fuel starvation the whole engine may be running on the hot side and causing your vapour lock issues. I was suffering with some vapour lock on hot days in summer in my Daimler, and ultimately switching to a cooler thermostat solved the issue.
Jun 15, 2022 13:54:02 GMT |
Hi, Fuel starvation or vapour lock is usually heat soak in the fuel pump area. If the fuel vaporises there the pump can't pump the vapour it can only pump liquid, equally the supply pipe.
Colin
melle
South West
It'll come out in the wash.
Jun 15, 2022 13:54:11 GMT |
Some aluminium sheet with reflective gold tape on the underside would be a quick & cheap solution . Aluminium is a pretty good thermal conductor, and the gold tape won't do much to stop that I suppose. I may be wrong, but I think reflection only works at surfaces and not in between two solid materials? A piece of hard wood is cheap/ free, easy to machine and insulates very well.
Last Edit: Jun 15, 2022 13:54:39 GMT by melle
Jun 15, 2022 15:01:25 GMT |
You need a bit of phenolic sheet (Tufnol trade name maybe), maybe 6 - 8mm thick (or a bit thicker if you want to machine it at an angle). You can then cut it out to shape with wood working tools an add a gasket each side. Plenty of OEMs used just this “technology”.
Nick
Jun 15, 2022 18:38:35 GMT |
Thank you for your reply. Well the issue of fuel starvation only happens when accelerating up a hill and not when accelerating on the flat. This issue has only started since changing the engine angle to overcome another issue. I have an electric fuel pump next to the fuel tank in the rear. the fuel is boiling away from the carb when the engine is switched off when hot. I am assuming this is the issue for poor starting.
Jun 15, 2022 18:39:58 GMT |
Thanks Nick I'll have a search for some.
Jun 15, 2022 21:04:05 GMT |
For the fuel the best thing is to fit a return line, as others have said i'm suprised a small change in angle had had an effect, can you turn the carb 180 degrees or raise the float level slightly?
madmog
Club RR Member Number: 46
Carburettor issuesmadmog
@madmog
Club Retro Rides Member 46
Jun 16, 2022 10:39:36 GMT |
As well as the phenolic sheet, and the correct angle, is it possible to duct some air at the body of the carburettor or at least in the general direction to dissipate some of the heat build-up?
