Used in Porsche's and Mercedes Benz.
Does anybody have experience with them?
What are they used for, normally?
From what I can find, they store brake fluid at high pressure ( 120 Bar ).
Reason I'm asking, I'm still not totally happy with my electric power steering setup.
It acts perfectly, most of the time.
But in extreme situations ( like when you try to catch a racecar in a slide ), it cuts power to it.
This is a "safety feature", apparently...
So I think my options are:
- Start over with a electric power steering pump that isnt quite as "safe"
- Go caveman on the existing pump, and see if the extra "safety" can be removed.
- Start over with a engine driven pump ( no electronics to safe me from the sudden & quick steering inputs I built this car for )
- Mount a 2nd pump in parallel, so the the drop in volume will be half.
- Try to fool the existing system into thinking there is nothing extreme going on ( which is where the accumulator would come in )
For about $100 and some plumbing, it might be worth to try.
What do you guys think?
