ChrisT
As per title, just looking for something to treat the underside of my modern before it gets too bad and came across this stuff on a Google search. www.lanoguard.co.uk/Not heard of it before, seems to be a few good reviews of it online.
Jun 16, 2022 17:52:56 GMT |
I was also wondering?
It will come in handy even if you never use it
slater
Club RR Member Number: 78
I've not actually used it but it appears not to be a permanent under body wax but more of a blast it over everything each autumn and its it's somewhat sacrificial. It's just lanolin. (Ie. the oils out of a sheeps fleece) so I'm pretty sure its main credentials are eco ones. An alternative to old engine oil and maybe waxoil.
ChrisT
I've not actually used it but it appears not to be a permanent under body wax but more of a blast it over everything each autumn and its it's somewhat sacrificial. It's just lanolin. (Ie. the oils out of a sheeps fleece) so I'm pretty sure its main credentials are eco ones. An alternative to old engine oil and maybe waxoil. That all makes sense, guessed from the name it was a sheep based product. Think I'll just stick with the Dinitrol stuff, remembered the other day I've got a couple of cans sat in the garage.
