Jun 17, 2022 19:27:14 GMT |
Yes since posting 4 x 108 was correct Also want to fit after market steering wheel and from what ive read its mostly Citroen Visa front wards so trying to clarify if Visa wheel boss will fit a 2002 model / searched Google inside out upside down trying to verify that unless an RR member as details ?
Started out with nothing and have most of it left.
Jun 17, 2022 21:56:16 GMT |
It’s basically a visa/ Peugeot 205 front with a van rear. I’m confident a 205 wheel boss would fit
Bit of searching found this information: Citroen Steering Rack 84 onwards shows same as Peugeot 205 87 onwards So would assume need wheel boss for 205 87 onwards Sure now fine checking will put me on right road Thanks for info so far
Last Edit: Jun 18, 2022 10:21:33 GMT by Quasimoto
Jun 18, 2022 10:38:58 GMT |
It’s basically a visa/ Peugeot 205 front with a van rear. Bit like this then.  Perhaps I should put that in the "cars you never knew existed thread" The Visa diesels and GTis were four stud IIRC. I was once given a dead 205 diesel that had power steering and thought it would be a great exercise to fit it to my first C15 van as the Pepperpots did make the steering a bit heavy. I carefully removed all the necessary bits and pieces one day but found that the column was different enough to mean I would need to source a P/S C15/Visa column. I then found out that the top mounts on the front struts had both seized and the coil springs were winding when the wheels turned. So I fitted the struts from the 205 instead and the van felt like it had power steering after that anyway.
'57 Austin Cambridge A55 1800 Overdrive '50 MG Y-type (In build) '56 Standard Super 10 (In build) '80 Toyota Corolla 1.6 Liftback (in the queue) '03 Fiat Stilo Abarth (Wet weather runabout) '05 Citroen Berlingo (Parts hauler)
Jun 18, 2022 14:20:27 GMT |
Still double checking on the Peugeot 205 boss kit fitting and it needs to be later 205 from all accounts / any info welcome
Jun 18, 2022 16:26:28 GMT |
Could nt find any original window winders anywhere so a generic set fitted well enough and matched interior
Jun 18, 2022 17:42:09 GMT |
The Visa diesels and GTis were four stud IIRC. You recall correctly. 4x108, 66mm centrebore.
Jun 18, 2022 17:44:07 GMT |
They actually did a group b Citroen visa rally car. Several in fact - the Trophee, Chrono & Mille Piste.
norm75
Jun 19, 2022 13:44:21 GMT |
They actually did a group b Citroen visa rally car. Several in fact - the Trophee, Chrono & Mille Piste. yes I know. The milled piste was 4x4 too.
Brigsy
Seen this one a while back and looks great. Some lows and wheels and yours will look spot on
Last Edit: Jun 20, 2022 9:46:51 GMT by Brigsy
Jun 20, 2022 11:12:36 GMT |
A friend of mine ended up with one of these around this time last year, ended up getting rid after a few months but not after cutting the springs and fitting some 17x7.5 Peugeot steels
Jun 20, 2022 19:39:38 GMT |
Just took off ( read cut and struggled ) really heavy back box and replaced with straight stainless pipe / not too big as to draw attention but sounds a lot better for an afternoons work
tom13
Jun 21, 2022 13:15:29 GMT |
Love this. Keep it up.
Still looking into wheel boss kit after RR member suggested Peugeot 205 and apparently there were two variants and as my Citroen C15 is 2002 it was suggested the later Peugeot wheel boss from 205 would be the one / anyone know more about this and fitment ?
Jun 24, 2022 17:05:31 GMT |
Might be a diesel but having taken off the strangulation device known as the air filter box it was on with a generic induction kit formed from an alloy section from one fleabay seller and generic cone filter from another. Whether it produces any more power doesnt matter / its not a speed demon and at best it ll breathe that bit easier. One thing about modifying an old retro is there aint no rule book / no hard and fast calculation as to will the rivet counters object nor is it going to help / hinder / improve performance / purely for fun and a little bit of differentology on a Friday afternoon. That is what non serious retro ownership is about for me !!!!! Had good fun fabricating a bracket to bolt to air filter using up bits n bobs left over from earlier window winder job.
village
Always carries a toolbox. Because Volkswagen.......
Jun 24, 2022 21:02:42 GMT |
Back in the early 90's I was in the Malvern Theatre Players and the guy who ran it had a petrol one of these. He used it to pull a 24ft twin axle flatbed trailer, usually loaded up with bits of theatre scenery, along with about 5 or 6 passengers. And Malvern ain't flat....
"The White Van is strong with this one...."
Chris "Chesney" Allen 1976-2005 RIP
Thats a great testament to the fact they are a willing work horse when needed Diesel aint the quickest but it sure sounds interesting with its new additions and as a cheap fun project not to be taken serious so far its delivered. Why have normal when for less you can be individual
Differentology
Last Edit: Jun 25, 2022 8:11:23 GMT by Rich
Jun 25, 2022 16:56:42 GMT |
Finished off the exhaust with a period stainless Sebring stainless tail pipe trim.
Jun 25, 2022 17:00:02 GMT |
Nothing that stands out thats big / brash or otherwise but the end result is nigh on straight through exhaust that just burbles around town but livens up if you hit the gas pedal and its all just a bit of cheap retro fun nothing too serious
