Offering the engine from my V2 STi Type RA. Its low mileage, just 60,000 miles with cambelt kit including tensioners and pulleys as well as water pump and thermostat all changed less than 1000 miles ago. For those that don't know these earlier engines have the stronger closed deck block, STi Cams, Hollow valves and forged pistons. The engine is completely original and perfect for a restoration or car being put back to stock, It ran super smooth prior to breaking the car down due to rust from a leaking battery.
I'm looking for £3000 Collection from Chippenham, Wiltshire
could ship on a pallet but they seem expensive at the moment. I do end up in Mid Wales quite often so could deliver up that way. I have interest in someone buying end of June but I'd rather not wait that long as I have my eye on a car.
Sale includes:
- Low mileage Closed Deck STi Engine
- Type RA Inlet Manifold with 5th Injector Port
- ECU
- Stock exhaust manifold and up pipe
- Stock TD05 Turbo
- Coilpacks & Plugs
- Injectors
- Sensors
- Starter Motor
- Alternator
- Engine brackets and mounts
Does not include power steering setup or intercooler.
Sale includes:
- ECU
- Stock TD05 Turbo
- Coilpacks & Plugs
- Injectors
- Sensors
- Starter Motor
- Alternator
