I had hoped to spray the van in two goes using the airless sprayer but smaller sections are going to need covered much more frequently due to surface rust.
To save setting up and cleaning the gun every time does anybody recomend a place to bulk buy primer in aerosols?
Once prepped I can do the while van in a booth but until I get to that point this thing is going to need covered.
Thanks
You want to use aerosols to prime a van? I hope the van is still driveable, as you'll need it to get them home.
When I want to prime large areas with the first coat of primer, I use a roller. Clean the tray with thinners, and use a new roller cover next time. Quicker, easier and much cheaper. Works really well with 2k primer filler too; often a second coat isn't necessary
slater
Club RR Member Number: 78
Aerosol primerslater
@slater
Club Retro Rides Member 78
May 26, 2022 10:17:18 GMT
Ebay
+1 for just rolling or brushing it on to start with tho.
May 26, 2022 11:42:34 GMT
It's a really small van.
It really just to keep the repairs covered. It's mainly along the roof gutters so it's probably not worth trying to get s roller in but I might give a large brush a go. It'll have to be rubbed down anyway
May 26, 2022 17:50:43 GMT
It's a really small van. It really just to keep the repairs covered. It's mainly along the roof gutters so it's probably not worth trying to get s roller in but I might give a large brush a go. It'll have to be rubbed down anyway Buy the rollers from Poundland. You'll get several different sizes for the cost of a brush that will apply car paint without losing any bristles.
