May 22, 2022 18:37:27 GMT
ive just painted the engine bay in my mini, and i had a thought, its primed in hp body 534 high build, then ive painted over that in 2k paint. is that the right thing to do? should i have used a sealer or some other primer first? I am going to be painting the rest of the car soon, so don't want to mess it up thanks
May 22, 2022 19:18:35 GMT
Hp Body 534 is a 2k primer ? Engine bay looks Good
May 22, 2022 19:24:41 GMT
its a 2k high build primer. thanks for the comment
May 22, 2022 19:33:39 GMT
I'm just painting My Anglia From bare metal and I have epoxy primed then filled re-applied the epoxy and Then 2k High Build
I have used Mipa 2k Epoxy
Don't think there is any need for further coatings after high build
Last Edit: May 22, 2022 19:41:18 GMT by cpj105e
May 22, 2022 19:38:15 GMT
right ok thanks, ive just used the high build no other primers.
Ritchie
Club RR Member Number: 12
2k high build primerRitchie
@ritchie
Club Retro Rides Member 12
I'm just painting My Anglia From bare metal and I have epoxy primed then filled re-applied the epoxy and Then 2k High Build I have used Mipa 2k Epoxy Don't think there is any need for further coatings after high build Did you just recover the filled bits or a full coat?
May 23, 2022 18:20:31 GMT
I have done Full coat as i was out of the drying window time . So flatted it off First
I guess you could just do filled bits before High build .
