mrbig
Semi-professional Procrastinator
Apr 25, 2022 17:35:27 GMT
Evening learned compadres. Rather annoyingly the powdercoat on my beetle axle is failing (peeling on sharp edges). I’ve elected to strip and etch prime/paint it but what’s the best way to get the old stuff off?
I’m using a Norton Blaze Rapid Strip disc on my angle grinder at the moment which is chuffing awesome, but they are £10 a pop and I’m burning through it at quite a rate. Any suggestions for cheaper alternatives please?
Oh and is chassis black still the right choice for under car components?
1969 German Look Beetle - in progress
Apr 25, 2022 17:40:44 GMT
Standard flap disc makes short work of pretty much anything on an angle grinder.
Apr 25, 2022 18:21:42 GMT
Dichloromethane is the daddy for this job, but it'll proper mess you up bad if you don't wear protective gear and in a well ventilated area.
mrbig
Apr 26, 2022 14:49:49 GMT
Standard flap disc makes short work of pretty much anything on an angle grinder. How aggressive are flap discs? Don't think I've ever used one before? I've seen people using them to 'grind' down welds before, I don't want to be taking metal off?
Apr 26, 2022 15:40:17 GMT
You can get them in different grits. All of them are pretty aggressive, but you don't need to be hard with them. Just glancing them over the surface will take powder-coating off nicely without impacting the metal underneath significantly.
I've be careful on edges and profiles though. They work nicely on flatish areas because it spreads out the area of the sanding disc, but if there's a lip or edge it'll go through that quite quickly if you're not careful.
Apr 26, 2022 17:10:29 GMT
How aggressive are flap discs? Don't think I've ever used one before? I've seen people using them to 'grind' down welds before, I don't want to be taking metal off? You can get 40 grit through to 320 grit so they can be pretty brutal or as gentle as you want to be. I've got a grinder with adjustable speed control which is worth its weight in gold.
Apr 26, 2022 18:34:43 GMT
We use Dichloromethane at work - dissolves powder coat like thinners dissolve paint.
mrbig
Apr 26, 2022 20:43:53 GMT
Trouble is I've got Delrin bushes inside and chemicals will probably turn them into a gelatinous mess!
madmog
Club RR Member Number: 46
Revival of an old-ish thread. Are the Beetle axles cast? I have bad luck with powder coating in particular on castings, it flakes off.
Vitesse 6 Saloon Vitesse Mk2 Convertible BMW R1150GS VW Amarok
mrbig
I'm pretty sure they are, yes. Going for etch primer and paint this time!
Hi, the lesson to be learnt here is to round off the sharp edges, paint doesn't stick to sharp edges it pulls back from the edge and so it seems does powder coat. You don't have to go mad just a slight radius will do.
Colin
mrbig
Thanks Colin. The issue I have is that the end plates are exactly that - laser cut from plate, so there are number of right angle edges to deal with.
mrbig
Dec 14, 2022 14:51:04 GMT
Right, so after many hours of curse word the neighbours off with the angle grinder and strip discs, I gave up and took it back to Paul at Redditch Shotblasting who blasted it back to bare metal whilst carefully masking up the bushes. As ever, Paul did a great job and I've got it back home ready for paint. I need to give it a blast over with the airline but then it needs a clean and degrease. What does everyone use to degrease ready for paint? Regular panel wipe like this amzn.eu/d/7Gmm4QH and tack cloths?
Dec 14, 2022 15:34:07 GMT
yes you can use that or on bare metal parts I just use gunwash celly thinners.
