Apr 24, 2022 18:10:38 GMT
I have got a fair bit of weld grinding to do in really tight corners, mostly door frames etc. I have a dremel type tool but no die grinder. What is everybody using to clean these up?
Thanks
Apr 24, 2022 18:15:50 GMT
Currently various shape carbide burrs and flap wheels. Keep meaning to invest in a finger sander though as they look handy.
Apr 24, 2022 18:37:11 GMT
Have you seen the toy tool sets for three year olds? The ones that have a plastic saw, bendy screwdriver and a drill with a motor sound? That's what a Dremel is compared to a die grinder and a carbide burr.
I use a die grinder with a carbide burr, still not as quick as a grinder and not so easy to control but it's about the best I have found.
Apr 26, 2022 11:54:41 GMT
Have you seen the toy tool sets for three year olds? The ones that have a plastic saw, bendy screwdriver and a drill with a motor sound? That's what a Dremel is compared to a die grinder and a carbide burr. Indeed, but I've got some areas where only the tiny Dremel will go, so there's no option. The best thing is to have a selection so you can call on them as required.
goldnrust
West Midlands
Minimalist
Apr 26, 2022 15:34:32 GMT
Finger sander / power file / whatever you wanna call it, is my tool of choice for welds in things like door frames.
It won't quite get into the places that a die grinder might, but it works for most situations and is cheaper than a good die grinder and is something I generally find useful for other bits of detail sanding / filing.
Apr 26, 2022 19:39:46 GMT
Finger sander / power file / whatever you wanna call it, is my tool of choice for welds in things like door frames. It won't quite get into the places that a die grinder might, but it works for most situations and is cheaper than a good die grinder and is something I generally find useful for other bits of detail sanding / filing. I agree, I use a Black and Decker one, I think its a KA900E and I buy the zirconia belts for it off e-bay.
Its really good for getting into the tight corners.
