spiny
Wiki Admin
I am abivalent towards car electrics ...
Club RR Member Number: 167
Apr 21, 2022 20:30:51 GMT
spiny
Wiki Admin
Apr 21, 2022 20:32:02 GMT
spiny
Wiki Admin
Apr 21, 2022 20:33:17 GMT
spiny
Wiki Admin
Apr 21, 2022 20:34:19 GMT
spiny
Wiki Admin
Apr 21, 2022 20:35:53 GMT
So, my first question is: where would I source a coupler to replace the broken one? A brief search shows other mowers like this one using solid couplers, is that acceptable ?
tonup
Apr 21, 2022 20:43:53 GMT
I love an old mower! If you grind off the flanges of the existing coupling, find a short length of snug fitting car radiator hose and a couple of jubilee clips each end and it will last for ages.
spiny
Wiki Admin
Apr 21, 2022 20:54:45 GMT
I love an old mower! If you grind off the flanges of the existing coupling, find a short length of snug fitting car radiator hose and a couple of jubilee clips each end and it will last for ages. cool, I'll give that a go
Cool find. I was going to recommend a Ruland jaw type coupler. The ends come in all diameters. But the rad hose idea sounds like it'll work. I wouldn't go solid, the coupler allows for a bit of misalignment and it'll stop it knocking its bearings out.
Last Edit: Apr 22, 2022 8:38:21 GMT by Jonny69
spiny
Wiki Admin
Apr 23, 2022 20:58:01 GMT
spiny
Wiki Admin
Apr 23, 2022 20:58:35 GMT
Cool find. I was going to recommend a Ruland jaw type coupler. The ends come in all diameters. But the rad hose idea sounds like it'll work. I wouldn't go solid, the coupler allows for a bit of misalignment and it'll stop it knocking its bearings out. cool, that looks a lot more sensible
spiny
Wiki Admin
Apr 24, 2022 10:37:46 GMT
spiny
Wiki Admin
Apr 24, 2022 12:14:29 GMT
Last Edit: Apr 24, 2022 12:17:06 GMT by spiny
I wouldn't worry too much about the rough ground. The more often you mow it the smoother it will get. I'm impressed with the cutting capacity of that thing. Did it make quite hard work of the long thick grass or just take it in its stride as it were?
spiny
Wiki Admin
I wouldn't worry too much about the rough ground. The more often you mow it the smoother it will get. I'm impressed with the cutting capacity of that thing. Did it make quite hard work of the long thick grass or just take it in its stride as it were? Even with the rusty blades it went through it like it wasn't even there, the cut is night and day compared to the cheapo 'spinning blade' flymo type mower I normally use.
