I'm trying to rebuild an early Jag IRS (probably an E-Type one) but I need the tech info to be able to do it properly, does anyone have a workshop manual they could scan/copy the info from?
Specifically the fulcrum arm bearings shimming info, all torque wrench settings, toe in shim settings and any other info I might need.
Thanks in advance for any help.
