OPEN TO OFFERS
4 x Compomotive 17"x7" ML Minilite wheels
Very rare wheels that Compomotive no longer make in this size.
Manufactured in 2003
PCD is 4x114.3
which fits MGB GT, MGV8, some Japanese cars.
Centre bore size is approx 64mm
Offset is approx ET37
205/45/17 Avon ZZ3 tyres have approx 5mm of tread
I bought these to have machined into a 4x100 PCD to fit a Mini. But I don't want to drill more holes into them. They have a solid back mounting area so this could still be done. Or you could use PCD hubcentric spacers. I cannot use these on a Mini as the offset woult be ET17 with 20mm spacers fitted. |They would stick out of the arches too far.
Wheels are in good condition with only a few minor marks on them. They are very presentable.
They come with Compomotive aluminium centre caps, which are a bit scratched and also 16 x MGBGT wheel nuts and washers.
The holes in the back of the wheels (pic 7) are where 15mm spacers were bolted on. I can supply these too if going onto an MGB.
The wheels are located in Billingham, Cleveland. I may post.
PCD is 4x114.3
