Mar 18, 2022 20:50:51 GMT
i have now a Burgess bandsaw, its quite old, and if it worked right, it would do the job i want it to fine. But the blade keeps coming off, and also, it cuts slow. The things i want to cut with it is say 2.5" exhaust pipe, 3-4mm plate, and just general other bits.
is there a bandsaw that will suit me that isnt so expense and not massive?
it will nto be for wood, only metal thanks!
Mar 18, 2022 21:15:11 GMT
Apparently Aldi's one is worth looking out for, not always available though
Mar 18, 2022 21:18:15 GMT
oh nice one, googled for it and that looks good. just don't want to buy another one that isnt good enough.
Mar 18, 2022 21:23:32 GMT
Mar 19, 2022 11:08:43 GMT
IIRC there's a thread on "diyNOT" forum about the Aldi one, and some youtubes
melle
South West
It'll come out in the wash.
Mar 19, 2022 15:01:28 GMT
The one in the Aldi link does 1400 rpm, which is way too fast for cutting steel, the only thing you'll probably achieve is instantly dulling your saw if you're lucky, or the band snapping if you're not. The bands you can get for small hobby band saws are usually not suited for steel anyway, they're really only useful for woods and plastics.
Mar 19, 2022 21:19:35 GMT
the burgess one i have does the job but the blade keeps coming off. I cant work out why! maybe i should just work out whats going wrong then?
melle
South West
Mar 19, 2022 22:53:12 GMT
Have you tried adjusting the tracking of the wheels?
Edit: I just googled Burgess band saw, is yours one of those 3-wheel jobbies? I can hardly believe that cuts 4mm steel plate.
Last Edit: Mar 19, 2022 22:57:36 GMT by melle
yes thats the one, it does cut it but takes ages. really good for exhaust pipe which is what i do most on it.
melle
South West
Mar 20, 2022 11:18:30 GMT
Wow, what make/ type bands do you use? I have a small FERM saw (FLZ-275), but the only bands I can get for it are for wood, plastic and maybe brass or other non-ferrous metals. I don't think the type of motor allows for the speed to be dialled down (mine only has one speed), so I would think it's no good for steel anyway. Mine is spot-on for my usual needs, if I need to cut thick-ish sheet steel I use a mate's professional metal cutting band saw, or a jigsaw for short cuts, and a hacksaw-type cut-off saw or an angle grinder for pipe etc.
If adjusting the tracking doesn't work for you, perhaps you can get new tyres for the wheels? I replaced all the bearings in mine when I got it (second hand), which made it run much more smoothly.
Mar 20, 2022 21:42:53 GMT
its when the blade catches, it some how jumps off. its quite a slow cut, it takes maybe 3-5 mins to cut 50mm exhaust pipe. the blade came from ebay, it is for steal.
maybe it does need new tyres! i think the best option for me is to fix what i have then.
Mar 20, 2022 21:51:18 GMT
I've just bought one of the evolution chop saws, it seems completely wrong but it cuts steel pipe & bar amazingly.
OGDB
Mar 20, 2022 22:18:44 GMT
slater
Club RR Member Number: 78
metal bandsawslater
@slater
Club Retro Rides Member 78
The best thing for diyer is usually to get a horizontal saw and fit a plate to the lower blade guide so you can use it as a vertical when needs be. Even I do that over having two machines.
