gezzard
Club RR Member Number: 69
Feb 27, 2022 16:47:15 GMT |
Car has MOT until January 2023, Starts and runs, will drive but konks out out junctions and at idle, but to be honest I've lost interest.
I changed the accelerator pump diaphragm as it was perished and leaking fuel.
has had a new Lucas alternator, dayco belt, original vauxhall spark plugs, Bosch HT leads, Lucas distributor cap and Lucas rotor arm in the last month, fitted by myself. fairly recent all weather tyres fitted too
62000 miles. paint has flaked away in patches mainly the roof.
selling as I have lost interest as it won't start. will need either towing, low loader or trailering away.
It's in Gillingham KENT.
I have the V5 and a few other documents, plus vauxhall filters, spark plugs, a new rear light lense, plus some brake parts.
£650 it's in Gillingham, Kent ME7 postcode
Last Edit: Apr 17, 2022 13:56:51 GMT by gezzard: Now sold.
gezzard
I've got it starting, took it for a quick spin, but it is cutting out at junctions, and at idle.
Have some new vacuum hose on order so will change that, may try and adjust the idle, and clean the fuel pump filter.
To get it going I put all the original plugs, leads, dizzy cap and rotor arm, back on but the new ones are there.
Last Edit: Mar 8, 2022 12:05:44 GMT by gezzard
So nice to see one of these. To think they were a common site on our road 20+ years ago, and now all but disappeared.
GLWS.
Love for old BMWs, Mercedes, Jaguars and Swedish Slabs!
gezzard
Thanks, I bought it to use as my daily driver, if I can get it running I'll keep it, as you're right you don't see them these days.
gezzard
Mar 20, 2022 15:14:30 GMT |
Still not running properly, and I need it out of the way, so price dropped to £650.
Last Edit: Mar 20, 2022 15:14:53 GMT by gezzard
gezzard
Mar 25, 2022 12:00:32 GMT |
Hi. Yes, still on the original pierburg 2e3.
I did think about replacing it with a Weber, but the cost (around £400 from webcon) put me off.
Last Edit: Mar 25, 2022 12:02:16 GMT by gezzard
Mar 25, 2022 12:57:35 GMT |
Hi. Yes, still on the original pierburg 2e3. I did think about replacing it with a Weber, but the cost (around £400 from webcon) put me off. I did that to a 1.3 estate a few years ago. The difference with the Weber was like night and day, worth every penny. Shame this is an auto, or I'd be tempted. Should be an easy fix for someone.
Mar 25, 2022 17:17:40 GMT |
There is also an enrichment valve on the 2e3 which is a perishable part, on the auto carbs they have a damper to stop the throttle snapping shut too quickly to prevent stalling, the auto choke has a flow and return from the cooling system which is common to block up meaning the auto choke doesnt work properly, they are complicated carbs but if you work through them sensibly you can normally get to the bottom of the problems
gezzard
Mar 27, 2022 22:48:27 GMT |
I pulled of those pipes and the coolant seemed to be running through ok.
I've adjusted the idle, so it's running and took it out for a spin, drives ok, although it pretty much accelerates to 30mph on it's own!
Most definitely not the solution, but if your local and interested it might get you home!
gezzard
Mar 30, 2022 20:05:19 GMT |
Some extra photos of the interior and engine bay. I'm open to offers on this!
gezzard
£600 Ono. I need this out of the way.
Apr 11, 2022 21:22:28 GMT |
Hi there, spec and rough price on the wet if it's available to buy?
Thanks
gezzard
Apr 12, 2022 13:35:10 GMT |
This sold on eBay for £530, I'm waiting for the guy to arrange to collect it, it won't drive very far so he's looking into having it picked up.
As for spec it's just an Astra 1.6L Auto, manual windows, manual sunroof, velour(ish) brown interior, it does have power steering!
Sold and collected.
Last Edit: Apr 17, 2022 13:56:28 GMT by gezzard
