broady
East Midlands
So not quite as the clock told the story. I took my manifold in for blasting, as the VHT paint hasn’t lasted too well. As luck would have it, my tame powder coater has begun learning how to ceramic coat. So it was agreed I would be a trial customer for one of their new products. I fail the before photo test. I ask for the same bright silver id used to match the rest of the engine silver. They had titanium silver in stock. So gave it ago, unfortunately it came out very grey. As they're kind souls, I asked them to make it more silver. So they ordered in a much brighter tone and this is what was return to me. Ignore the silver over spray on the underlay, thats from a previous job. But I had to say, that manifold looks exactly how I want it too. This ready and waiting I thought I best get on with bolting in something for it to attached too. Though there was 1 more modification to carry out first. Its not uncommon for the 944 to spontaneously combust. This is often owed too the two flexi fuel lines in the engine bay. they're 39 years old on this example and now being exposed to ethanol. Small a mounts, but none the less some. These are swaged on to the steel fuel lines which run the length of the car, and this is a dock yard job to change them. There are a few kits available for replacing them, but they're a bit pricey for what is effectively two rubber pipes and some compression fittings. I decided id work it out for my self. I started wit the tube cutter, and removed the main feed. Gulp. Several steps later Id been and had these two pipes made and bought an 8mm and 10mm steel compression fitting. Good for about 500psi. They unfortunately put a BSP fitting on, rather than a metric fitting, so I went back and they made me a new pipe free of charge. Once id mocked them up and was happy, I etched and passivated them. Access is tricky as they're behind the brake booster. But with the head and inlet off, I was able to get them installed. I will buy a couple of spanners and modify them for future use. My intention is to change this pipes every 4 or 5 years. As its now a relatively simple job to change them. You can just see the fittings in the back of shot here. And as if by magic the head was reinstalled and the manifold was mocked up. It was at this point I was a bit stuck. Id ordered a replacement set of exhaust manifold washers from Porsche, which were on the long lead time. Id planned to swap them later. But realising how much of a curse word it would be to do. I decided id wait a bit. As luck would have it I had to wait 2 days, as soon as I got the email saying they were in stock. I shot up to the dealer and collected them. This is why I needed new ones. Beyond saving. With a couple of other bits I don't really need. Some of you may have noticed the brake booster was looking a bit rough, this was from the dipstick tube when I removed the sump. I hadnt realised what id done, until I got out from under the car. This simply wouldnt do, so out with the masking and sand paper. There cant be much left to do now can there?
Last Edit: Apr 21, 2024 16:40:00 GMT by broady
teaboy
Make tea, not war.
Apr 21, 2024 14:20:16 GMT
Very thorough job there, dude.
I like the fuel hose modification.
bstardchild
Club RR Member Number: 71
1985 Porsche 944bstardchild
@bstardchild
Club Retro Rides Member 71
Apr 21, 2024 18:01:26 GMT
Ditto teaboy 's comments on the fuel hoses - very good job indeed - better than factory I really don't trust some of the modern fuel lines out there - the ethanol in modern petrol either eats them or they aren't of a similar quality that they used to be - I replaced all the fuel hoses on my big green minicab back in 2014 (no leaks after 23 years at that point so was just preventative as I was getting it back on the road after several years semi broken) - had to replace one of them again last month - it was cracked everywhere and spewing out fuel after 10 years.....)
broady
East Midlands
Apr 23, 2024 17:23:16 GMT
Cheers gents, much appreciated. Ive made a little change to them since too, which will be in the next update.
As you say, quality varys wildly. My aircooled VW, I replace those lines every 18-24 months. Until recently, I bought some pukka genuine ethanol proof stuff, its been on 3 years so far and its bob on.
But what I didnt think about was the fuel filter. I used an inline plastic jobby, I give it a visual a couple of times a year. It always been clean and the element nice and yellow. Over winter its sat there until one day it slid out the rubber hose (even though it was held with a hose clip). It dumped half a tank of fuel without me knowing.
I moved the car on to the drive, went in to the house to get my glasses and came back to find it stalled. It wouldnt restart, then I noticed the fuel guage reading zero. "I'm sure there was at least half a tank in there". I got the can out and tipped a gallon in, it came out as fast as it went in. Once I got under it an investigated, the filter plastic had gone soft and this collapsed a bit.
Moral of the story, ill be fitting a new 2 quid fuel filter every year, reguardless of condition. Cheaper than pouring £30 on the floor, or worse still onto a hot exhaust while I'm driving.
It's great how you've managed to turn this around in a short space of time, it'll be good to see the 944 back on the road soon
broady
East Midlands
Apr 26, 2024 19:55:48 GMT
It's great how you've managed to turn this around in a short space of time, it'll be good to see the 944 back on the road soon Cheers dude, weridly to me it felt like it took a long time! Reality is thats its been around 5 weeks. So I guess thats not a long time really, when youre working a full time job and living a life as well. Unrelated, but you know, while I'm ordering stuff from Porsche and paying the bridge toll to go pick it up, I may as well make it worth while? I ordered an indicator drain, as my passenger side one has been missing for some years, you may have spotted it in my parts pile earlier and wondered what it was. Here it is installed, but ignore the dirt. Obviously making it go vroom vroom is more important that cleaning at the moment. Here be them new fuel lines. The next bits arent terribly exciting, its just clean up and assembly, no real creativity or preservation. I routed the new fuel hoses through. I wasnt happy, they didnt look right. I couldnt place what was wrong. I refered to my "before" photos and realised the return line took a happier route. Next job was to fill 'er up with liquid and turn the key. Idle is smoother and the engine is definitely more punchy. Ive got 100 miles covered now, few teething troubles to work on. But nothing thats detracting from the enjoyment. Unlike the weather, curse word down every day and hardly getting to 10c! At least I'm back on the road and didnt miss "summer"
Last Edit: Apr 26, 2024 19:59:28 GMT by broady
broady
East Midlands
May 25, 2024 19:28:14 GMT
A month already! Ive got a small update, but thats "still to come". For now I'm just a bit giddy, last night I was at a very small event a Bicester heritage and Hertz team Jota had loaned their display car. I felt it would be rude not to park next to big brother.
broady
East Midlands
I'm back, I think? So reasons why I havent been doing much on the banger. The missus required some DIY to completed (it isnt finished yet, but shhh). I also wanted some days out and to go to a few events that id promised myself I would but never got round too. In late April the under the stair’s cupboard got opened up. As with all understairs space, everything was very neatly stored. We spend a bank holiday Saturday afternoon clear it all out, to find that half of it was junk and went straight in the bin. Because thats what bank holiday weekends are made for right? I removed the old false wall and associated clutter. Which left this space. Some measuring, timbering, and draw runnering later gave rise to the basics. Oh there was also fillering and painting of the behind the scenes stuff, to keep it looking respectable. . I than made some carcases? carci? Then there were shelved and lining. All of this has been interspersed with trips to B and Q, but not the local one. They fail to stock anything useful, so rides to Lincoln for extra fun. And if it wasn’t B and Q there have been trips to Screwfix as well. It has resulted in the "need" for a new tool. I got one of these fangled Bosch Impact drivers with the 1/4 bit holder and 1/2 socket adapter on. And its dead good and all that. *product review. Just painting and a few loose ends to tidy up now, so toy time should resume shortly. Those events? Well one you have seen evidence off as I'm parked next to the 963. As I wasn’t working at it this year, I went to the DHF to help out a mate with a couple or 3 pre war Aston Martins. I forget how we got on, I think 3rd is class was achieved. There was other nostalgia there too. So I jumped on the pit wall to see on touring car things And as it happened, there was rather a large display from PCGB, so it seemed rude not to. Some modern history was there as well, owing to a traffic jam my arrival was time to perfectly coincide with the end of their demo laps. This pleased me no end. Of course the secret motive of all this was, to get some miles on the 944 and run that engine in. It ran very well there and about. about 150 mile round trip. But as you can see, it starting to think it came out of Mr Newey pen, that rear is rather high. It has settled rather high, especial when the fuel level is getting low. This will be corrected in my next round of "fixing my Porsche" Oh yeah my Porsche, I have done some work on that too. Nothing that matters, apart from it mattering to me. PS I went to the wolds trophy at cadwell because I simply don't spend enough time around old cars as it is. I also took the Fasty, and the missus for a run up the coast to see where the coast used to be. 4.5m a year disappears here, we didnt hang around too long to find out, we went for ice cream and then came home. Are you sufficiently convinced as to why I havent done much on the 944 yet? Lets have a small but satisfying job. The plug for the pop up head lamps has no rubber boot, and to cure this I needed to de-pin the plug. curse word from ebay will manage this. The plug in question. Followed by the boot. I feel the loom needs a better route, which I tend to at a later date, those draws wont paint them selves. I have managed around 700 miles and other than drinking a pint of oil, all is well. So it will be getting an oil and filter change, inspection and rear end lowering. I called into to Porsche on Thursday evening to collect a couple of bits. And just like in the black and white days, they are using VW transporters to support their dealerships. This made me do smiling. For this service id "tret" is to a genuine oil filter too, the 944 part number was a nice touch. I will be sure to show it to everyone I meet. Next time ill actually do some work on the car, I promise.
Last Edit: Jun 12, 2024 17:32:03 GMT by broady
broady
East Midlands
Jun 12, 2024 20:46:01 GMT
broady
East Midlands
More stuff, I did some real work, I promise. Last week before I set to painting the understairs. I pulled the sump plug out and left it to drain for 24 hours, upon my return it was time to get the oil filter off. This has always been somewhat of a challenge in the 13 years ive own the car. Ive yet to figure out why I continued to curse word about. I have a filter chain, I would always try this first. It would often just start to move before denting the filter and thus no longer have the purchase to move it further. Id then try large grips, these never opened quite wide enough. Finally id resort to hammering a large spike through the can and it would turn just enough to free it off, then id be very annoyed about the oil leaking and carefully turning it while trying not to split my glove of cut myself. It has taken me 13 years to reach the point where I thought "why don't I buy the proper filter cap tool?". It turned out it was about £9, and I could get a set with many flavours for under £20. Thats a lot of words for "I changed the oil filter", I now cant wait to service the car next year! With this lovely simple task out the way, I needed to check the belt tension after the earlier hick up, I forgot to take any photos while doing this, but it was a lazy Sunday afternoon, sun was out, it was mild. Garage doors open. two good bits of news emerged, the belts were still well tensioned. They had settled in nicely, and there was no misting of oil in the belt cover, which there used to be. So the engine had definitely been breathing heaving for a long time. Next up was a job I planned to do over winter, if you cast you mind a long way back, when I first returned to the road I had got the balance shafts 180 degrees out. This caused a vibration and a few things undid them selves. One of which was the bolts holding the two halves of the alternator together. They ejected themselves into the lovely cast ally fan. It made one hell of a noise and scared the curse word out of me. Correcting the balance shafts and retightening the screws resolved this. But it didn’t fix my smashed up fan. And as this was an early alternator, cost savings on later cars made it quite hard to find a replacement. This is what I was left with. Clang! After much searching, all I was turning up were the replacements made of pressed steel. I enquired with OPC Hull and they said they could supply the original type. But between my enquiry and their answer a full alternator appeared on ebay. So I snapped it up. Never hurts to have a spare that I can fettle. I bit fluffy but solid, off to the powder coaters it went. Yes its fitted and no I didn’t remember to take any photos. But I'm sure you get the idea. Another one ive been getting round too, and no thats not clearing up all the oil yet. Because I still havent done it. But it was actually the front cross member bolts. 1 in particular could no longer decide what socket it needs. And wasn’t that far away from being round. I ordered a new one from Porsche. This arrived and as you can see, its more differenter So I ordered 3 more Installated This meant I could refit the undertray which id been routinely tripping over in the garage while building the draws under the stairs. My secret motive all along. So while it wasn’t exciting and I havent done a lot, it was worth while and it gave you something to read. If only briefly.
broady
East Midlands
Jul 30, 2024 17:44:21 GMT
Anyone remember that fuel leak from March? You know the one that was a fairly easy fix, just before the engine blew up? Well now was finally the time to sort it. I dropped the box, again, I'm a bit too good at this now. And then the tank, I had done some research on this topic, to see if there were any obvious things to check. There were a few threads talking about fatigue cracks in the steel tanks. Particually around a pressing in the top centre. I checked mine and sure enough, the coating had bubbled right there. Had we found the culprit? It would seem not, thankfully. I really didnt want to went into welding fuel tanks. After a good look over, the tank seemed to be ok. This left me 1 one simple idea, pressure test it. I had no fancy kit for this. I used anything I had laying around to blank things off. I huffed and puffed as best I could. The tank was expanding when I blew, I couldn’t hear any hissing and I was able to hold my thumb over the pipe and spray some soapy water around the joins. No bubbles. While it wasnt the most technical test, I was happy to trust the result. The filler neck was looking at bit grotty, and the seal I took off was knackered, so I addressed this. A cleaner, new seal. Thats the tank about as "looked" at as I can get it. I'm content that it wont leak. So I wrestled it back in. Followed by the gearbox. When I took the coupler off I noticed that the pinch bolts were starting to round, two fresh ones were ordered from OPC Hull. Everything went in rather smoothly, and the exhaust it back on. As one would expect given how fresh and recent it all it. To this end I went for a ride to the petrol station and brimmed the tank. For this I had left the filler neck cover off, so if it were to leak, I could spy from where. But I am pleased to report, not a drop was spilt. I went for a nice drive afterwards to slosh it round and see if I could make any fall out. It simply refused and I wore a smile. This cheered me up no end as the MOT was impending. A week later after a good wash. I set off in the direction of, I handed the tame tester a packet of biscuits and my car keys. This was to in no way try and persuade him to print a pass ticket. The first task was to check that gas was coming out of the pipe at the back. Computer says no. Some grunting and chuntering later, we decided to do the rest of the test and see if the computer would have got its act together by the end. It flatly refused and for the first time in my life, the test station failed the MOT rather than my car. They were fully booked up for a few days, so I will have to return another day and see if the garage will pass next time. On the way home I had a strange knocking noise, which I assumed would be something id forgotten to do up the previous weekend. I ducked under to check and all was well. My next thought was the jacking handle, its wedged with some foam, maybe the foam has fallen down? To check this the spare wheel needs to come out. Oh wait, the spare wheels loose. That'll sort that out then. With all that out the way and summer finally here, went to festival on the unexceptional at the weekend. Not the right car I know, I took the fasty last year. I put this little display in my boot of the tat ive gathered over the years.
broady
East Midlands
After a day of DIY, I need to pop to tesco. As a result of the sunny weather, I decided I would take the Porsche and the scenic route. Much joy was had, until I return to the car park. I noticed a small puddle under the car. It was coolant. After a quick check, I elected to top up the res with a bottle of water I had in the car and take a steady drive home. The temp needle was as happy as usual. I pull on the drive and jumped out. It was gone 9pm and I was a bit tired from the DIY, so I gave it a coursoury look. It appears to be coming from the water pump. I will take the belt covers off later today and inspect. This one just doesnt wanna live does it!
teaboy
Make tea, not war.
It’s a conspiracy, man!
broady
East Midlands
Definately! Its nothing to do with the pump being 11 years old and the recommended life being 8 years. I gave it a good check over in April when I did the head work. It was play free and smooth. Today I have remove it, its still play free, but its notchy AF. So I guess they last 10 years and 11 months
broady
East Midlands
Aug 11, 2024 19:13:22 GMT
What have I got to tell you then? Its been a week. One with a lot of achievement it has to be said. Last Sunday afternoon after id done some more painting in the hallway. Which needed to dry, I figure it was a good time to find out why it was having a wee wee. Once jacked up I still couldn’t see directly where it was coming from, but the end point, on the bottom of the power steering pump bracket could be fed from 1 of 3 places. First of all, the top rad hose which feeds into the head. This can easily be checked from above and was. All dry. 2, the water pump, can’t be checked with the timing belts on. 3, a crack in the block. At this point a water pump was the least painful hope. Fluid out and sleeves rolled up then. I spent about 3 steady hours getting down to the pump. As is always the job with this, its been apart enough times that I never have a stuck bolt to fight. This all the belts, pulleys, sprockets and guards out the way, were doing the nitty gritty. And that black dirty under the water pump pulley was the smoking gun I was looking for. That was tiny bits of rubber, showing the pump had been weeping sticky antifreeze and the notchy pump was obviously wearing the belt. So better it went now, rather than later and took the belt with it. Content I had found the problem I removed the pump and found what initially shocked me. Rusty mounting studs, my first look told me they were very tired. I ordered some replacements. After a few conversations with friends, they said clean em up and leave em alone, they aren’t as bad as I thought. I took a step back and looked at them a few days later. They were indeed right, a bit of surface fuzz but that was all. I did attempt to remove one, but it was stuck fast and I didn’t want to get into snapping one off and then having to take the front end apart in order to make room for a drill. So with my lesson learned, the recommendation is that the belts are changed every 4 years, the pump and tensioners every 8 years. With the latter nudging on for 11 years. I ordered a pump and a set of tensioners. Along with a new timing belt, the balance belt is new enough and non critical enough that reusing it will be ok. A new pump from OPC was knocking on for £700, which is too strong for my tasted. I ordered the tensioners and belt from them though as the prices were competitive. Pump wise I was pleased to find there is much more choice than 11 years ago and good quality at that. I got my hands on GEBA for under £200 on 48 hours delivery. As ever, its not just a straight fit, this needed painting to A) match the rest of the engine, and B) not look like corroded aluminium in 12 months time. I dusted this on over a couple of evenings during the week. I also cleaned down the mating faces on the block and had a general clean up around the front end. With all the prep done. I had planned to get up early Saturday and knock it out. Id estimated 4 hours to do it. So being done before lunch and then having a run would be ideal. This is a rare occasion where I out ran the Gant chart. Friday evening I came home full of vim. After tea I decided to crack on. Not the most exciting thing to be photographing. So I didn’t bother for the rest of it. But over the next 2 and a half hours I built it back up. Set the belt tensions, then I took a step back fora drink. Doubled checked everything and turned the key. We have life! I set the balance belt by ear, rather than by tension figure and let it run up to temperature. The rad fan kicked in and then back off again. I was happy and closed the garage door for the evening. There was however one casualty of the previous few hours. When changing direction of my ratchet, the tang broke off Luckily as its the fancy stuff, i should be on for a free replacement. Saturday morning rolled round, I tret me sent to a lion, but at 9am I still couldn’t help but go check the car. I bled the rad, followed with some DIY and then went for a run to Aldi for Mrs Broady. Everything worked as it should. I gave it a final afternoon check over and then as the sun was setting over the wolds I went for a sundowner run. It may test my patients at times but fudge me that’s a handsome devil.
Aug 12, 2024 13:36:02 GMT
You've put the hours in recently, it'll be good to see it again now it's running much better than last year!
broady
East Midlands
Nov 24, 2024 19:24:59 GMT
Christ was it August when I last said anything? The month after the last post was quite a busy one. I had a weekend away at skegvegas with friends. As some of you will have seen in my Fasty thread here I won a thing. I then had just over a week to finish the prep on a 1912 Talbot type M which I would be supporting on a VCC tour across Spain and France. This would be getting on for 3 weeks away. I will go light on the details to save time. But Spain in September. You'd expect it to be lovely, turns out it was mostly mid-teens and curse word down. Heres a few curated highlights. The route was roughly as follows. Bilbao-Pamplona-Zaragoza-Enge of androa-Barcelona-Peralada-Carcassonne-Montauban-Bordeaux-Le Mans-Caen We had a little incident; a tyre bead failed and blew off. Luckily it was on an arrow straight road. There was break down en mass as a number of cars filled up with dodgy fuel. We called in to make sure everyone was doing ok. Luckily the trouble truck was there draining tanks and refilling. We had drinks at the RAC club Bordeaux over looking the cars We had a little detour for lunch near cognac We of course drove as much of a lap as we could. Anyway you get the idea, very wealthy folk doing very wealthy things. Its a privilege to get to play along. This did of course lead to naff all happening with the 944. It had many miles put under its tyres when I got back. Everything has settled in nicely. Ive got a winter job list written, number 1 being a battery issue. After its sat for a week or more it becomes very slow to spin over. With the battery off the car, it still seems to go flat, so thats off away for testing/replacement. I also had a personal trip to Germany for museum reason, a friend and I went to the Mercedes and Porsche sheds. If you want photos of this trip too, pipe up now. I appreciate none of this really has much to do with my car, but its reason enough as to why ive done nowt. Wait theres more. My garage had become unworkable. It was piled with wibblepoo everywhere. So I took a week off work, aim number 1 clear the place out. I wont give you a blow by blow account of that. But I had made a major upgrade. We are going to have heating. I bought a Cheap cab heater for £68. Today I made some wall brackets for it. I now need to get an inch hole through the wall for the exhaust. A job for next week.
Last Edit: Nov 24, 2024 19:33:55 GMT by broady
