Sept 3, 2022 18:08:45 GMT |
Looking forward to the next updates!
I reckon that the small capacity Austin six is a much cooler option than the postwar Morris Minor lump. A bit more unusual, and less easy to identify too.
Last Edit: Sept 3, 2022 18:09:06 GMT by Paul H
Sept 3, 2022 21:22:19 GMT |
Looking forward to the next updates! I reckon that the small capacity Austin six is a much cooler option than the postwar Morris Minor lump. A bit more unusual, and less easy to identify too. More obscure and harder to identify was definitely part of the temptation. I've been asking around in Austin groups for additional information on it/to lock down whether it is the 1.5 or 1.7L and even they are struggling. The other benefit is like the low light motor it is relatively low profile compared with some of the big American 4 cylinder motors I had tried, so will sit better with my intended bonnet line.
Remade In Australia thereimaginarium.com.au
PhilA
Byte Wizard
You figure, your era there were little more than overgrown horse drawn carts.
Oct 28, 2022 12:12:32 GMT |
The things that follow you home  This came up on Ebay recently, close to the right proportions for the body and at a price I couldn't say no to. Came with some beautiful restored and original parts too. Rover 9/20
rob
Oct 28, 2022 17:42:03 GMT |
What size tyres are on that? I need a set of wings for a car I'm doing. They look about the right size so could be on the list of ones to look out for.
Oct 28, 2022 23:18:22 GMT |
Wow!
Oct 29, 2022 11:38:13 GMT |
Because I can't leave well enough alone I popped back out to the shed tonight, popped the lovely original 4 cylinder motor out, and swapped it for my Austin 6. To be honest I'm not sure if it was the right call. Aside from the engine mounting style I don't feel the Rover engine has much visual character. On the other hand it provided great proportion. The Austin 6 has more character, but I think it is a little too long for the body proportions now that I see it in situ. It will come up a bit when mounted, but is very close to mounted position. Just clears most things. I'll sit on the idea for a week or so, but I have a feeling that the little Rover will be going back in. Perhaps in time I can make a nice little cast alloy rocker cover to make it feel like an aftermarket OHV conversion and add some charm. Thoughts?
PhilA
Byte Wizard
Oct 29, 2022 14:51:49 GMT |
It's supposed to go fast. Take up the extra chassis with engine compartment.
Oct 29, 2022 19:23:11 GMT |
Crank the steering column lower and get those seats down on the chassis frame
Oct 29, 2022 19:27:33 GMT |
It's supposed to go fast. Take up the extra chassis with engine compartment. Fast is relative. This body initially sat with a single cylinder motor. The Rover is capable of 60mph, impressive from a 1itre motor from the 20s. The Austin is a 1.7L that can probably travel at 60mph rather than just reach it. I am concerned that I won't be able to get a pre ww1 looking bonnet over the Austin due to length and width relative to the body, but am not certain, will have to give it some thought.
Oct 29, 2022 19:29:56 GMT |
Crank the steering column lower and get those seats down on the chassis frame I am considering channeling it, but if I do that it will be a phase 2 with a replica of the body.
What size tyres are on that? I need a set of wings for a car I'm doing. They look about the right size so could be on the list of ones to look out for. They've got 19" motorcycle tyres wedged on, which seems about the rim diameter at the bead
rob
Perfect, thanks. That's the sort of size I'm after. What size tyres are on that? I need a set of wings for a car I'm doing. They look about the right size so could be on the list of ones to look out for. They've got 19" motorcycle tyres wedged on, which seems about the rim diameter at the bead
Slipped the Rover 4 cylinder back into the frame after much deliberation. It may be smaller and slower, but the width and length just suit the proportion of the body so much better and allow for a Renault/coal scuttle style bonnet, which I have a soft spot for and is a style not miles off the original.
I've pulled the original rear springs off and am considering using them as quarter elliptics. I have considered mounting one across the body Ford style, but they are too wide. Might still go down that route. I have the quarter elliptics from the Overland chassis but they are so rough I don't know if I want to use them. Running a couple of bars forward to repositioned original spring mounts,then a Ford style single spring sideways tucked under the back of the body just behind the rear axle could look good if I can find a suitable length/strength spring... In the meantime I bought this photo from eBay a month or so back. It is of an unknown car, but the body proportions are the closest I have ever seen in a period photo, so I had to grab it for reference. I'm pretty sure that it is on the same chassis and running the same motor that mine once would have. It makes me happy about the wheels I have for the car, the intended bonnet length and the positioning of axles, but does give me pause about the steering column angle, method of rear springing. It fascinates me that the rear guard is notched around the seat as the interaction between the parts looks like such an afterthought.
PhilA
Byte Wizard
Nov 12, 2022 11:41:24 GMT |
That one in the photo might be the same chassis but the running gear is different and it's definitely a bit of a bitsa too.
10 spoke, 5 lug wheels up front, 12 spoke rears. Looks like the wheels are larger than designed for, hence the incursion of the body into the mudguard.
The positioning of the steering column is bizarre, the arm being in such a low position compared to the rest of the underpinnings- feels either small manufacturer or slightly later homebrew from older affordable parts?
Phil
1904 Speedster Bitsaglenanderson
@glenanderson
Club Retro Rides Member 64
Nov 12, 2022 12:30:11 GMT |
That one in the photo might be the same chassis but the running gear is different and it's definitely a bit of a bitsa too. 10 spoke, 5 lug wheels up front, 12 spoke rears. Looks like the wheels are larger than designed for, hence the incursion of the body into the mudguard. The positioning of the steering column is bizarre, the arm being in such a low position compared to the rest of the underpinnings- feels either small manufacturer or slightly later homebrew from older affordable parts? Phil I’d put money on that being a 1920s built home made special.
Nov 12, 2022 20:40:01 GMT |
If it is that would be sort of fascinating. 2 home builts from opposite sides of the world with such similarities. The wheels look of similar size to my eye, perhaps the extra 2 spokes are just to take the braking and drive loads that only the back axle bears? That one in the photo might be the same chassis but the running gear is different and it's definitely a bit of a bitsa too. 10 spoke, 5 lug wheels up front, 12 spoke rears. Looks like the wheels are larger than designed for, hence the incursion of the body into the mudguard. The positioning of the steering column is bizarre, the arm being in such a low position compared to the rest of the underpinnings- feels either small manufacturer or slightly later homebrew from older affordable parts? Phil I’d put money on that being a 1920s built home made special.
