vanpeebles
I am eastbound in pursuit of a white Lamborghini, this is not a recording.
Sept 29, 2024 21:06:58 GMT
I managed to pick up two used tamiya trailers, one a tanker and one the reefer 3 axle, which seems to have all the axle and running gear etc, just no box on top. So pondering making that into a flat bed etc. Sounds like it’s a nice planked floor and headboard away from being a nice tri-axle flat That's exactly what I was thinking! Great pics of the run too!
Rich
Club RR Member Number: 160
Nov 19, 2024 19:51:01 GMT
So, since the last update. The roof came off the workshop (through choice, not weather) And after an extensive refit, I was left with a nice, dry warm space to work in. Finally. First thing I looked at were a few bits on the Merc, I fitted a sliding 5th wheel to allow hitching other trailers than the tipper, and replaced all the JIS head screws I could with hex head M3 bolts. I think did some 'graffiti' on a broken Huina exe as a trailer load, having sold the wheel loader as someone was interested in it.
Rich
Nov 19, 2024 19:58:10 GMT
Next on the block: Finish the dry van. Made up a better rear under-run bar, with reinforcing tubing to prevent the bar squashing Mockup with the rear door assembly After that, I started adding the rest of the lights to the framework. The rear doors I wasn't really sure what I wanted to do with, until I remembered I was given a load of dimpled alloy sheet. That could work... Final light test after assembly.. And finally, finished with the DOT conspicuity tape.
Rich
Nov 19, 2024 20:22:24 GMT
Next! Ford fell apart gain. I wanted to replace the lights on the bottom of the first fuel tanks, the colour was wrong and I wanted lights on both tanks. I was sorted out with these light bar sets, which do the job nicely enough. I kinda saw this as an opportunity to do a few other mods I'd wanted to for a while, namely the headlight LED colour and the black masking around the headlamp bezels as well as a blackout panel behind the grille. From cold, icy xenon blue to a warm sealed-beam white. With that done and the wiring modified to have less... wiring (taking advantage of Beier's common positive rather than running 6 positives, one for each LED) I moved on to the bumper which had always been held on with VHB and frequently fell off (when I bumped into things) I liked the clean look, but if anyone picked it up without knowing the bumper was just taped on and used it as a hand hold, it's bye bye Ford. So out with the M2 hex head bolts. I also repurposed some of the little lamp holders under the front slab as chicken lights (with the right colour LED in this time) Moving on to even more things I wanted to alter, the dash being RHD was one. The truck had been built as an Aussie lorry, which isn't my thing, so conversion to LHD underway. Utilising a poorly painted King dash I had kicking about, I grafted it into the Ford bulkhead. Holes? Ah yes, my mediocre attempt at making it light up. Dash isn't really accurate but the layout of the controls is as close as I could do with the square panels. Re-used the Ford steering wheel as it was nicer. Made a new gear lever, and in the driver went. He's had a few to drink, he's legless. I did also rewire the identification lamps on the cab roof from 10 to 2 wires (yea, I dunno either) but no pics of that. I added some period cab reading material and map sheets and that was that, back on it went. And there we go. Maybe. I have a few more of the torpedo ident lamps so temped to put some on the top sides of the sleeper. I'll sleep on it and see. Pun.
Last Edit: Nov 20, 2024 22:17:07 GMT by Rich
skinnylew
Club RR Member Number: 11
Nov 19, 2024 22:28:50 GMT
the detail in these is phenomenal! Wow!
jayj83
own 2005 Toyota avensis 2.0d Estate, 1993 Talbot Express Autosleeper Harmony
Nov 20, 2024 17:42:15 GMT
The detail is awesome on this
2005 Toyota Avensis 2.0d Estate 1993 Talbot Express Autosleeper Harmony
Rich
Nov 20, 2024 21:00:28 GMT
the detail in these is phenomenal! Wow! The detail is awesome on this Thanks guys, can’t take too much credit for the Ford as it came to me pretty much 85-90% finished, just needed finishing. I have another to build up though, at some point 😅
jayj83
Nov 21, 2024 11:32:19 GMT
Be good to see the other bulid as well
Rich
Nov 21, 2024 18:25:59 GMT
Be good to see the other bulid as well I’ll be posting as I go, for sure. I want to build my wrecker first though as that’s currently WIP. 👍🏻
vanpeebles
Nov 23, 2024 22:04:34 GMT
Where you get the square tubing?
Rich
Where you get the square tubing? B&Q of all places. The big ones have quite a handy if not slightly expensive selection of ally and brass profiles
Rich
After the Ford was all done, a friend popped up for a workshop day for some work on his ‘Volvos’, the first being a FH16 cab kit on a Scania chassis as Tamiya don’t make a FH16 6x4 tractor. I was called upon to fit a Beier USM-RC 3 along with a few other bits including skirts and deck plate. done. Next. His second ‘Volvo’ is a Freightliner Cascadia with a VN style grille. It had come to him with Grand Hauler arches seen in other pics which suited it as well as a pineapple hat on a Mod and some LEDs poked in a piece of aluminium stock as a bumper which interfered with most trailers. He’s recently had the DK Line graphics added so wanted a more working truck look so a while back he got hold of a (I think scaleclub) fancy rear transom which we added lamps to, and a set of big old flaps. And now back to my stuff..
Rich
So having been stalled on the wrecker build for a little (long) while now, aforementioned friend point me in the direction of this. Too good to pass up, I snapped it up. While the wrecker bed is nice it’s only single drive and I’d already built the one on the Globe so let’s move things over… Yup. That’ll work. Set about refining some of the part of it, like replacing the Tamiya JIS coarse screws and M3 screws where possible with hex headed bolts and built the sub-chassis for the bed from the original Globeliner kit rails. It’s now mounted to the bed rails and it’s sturdy. I also refined the mounts for the lift/brace assembly and that’s fitted although the scobie plate needs remaking properly. Very happy with the way this is looking now.
jayj83
they all look so life like, Wish I had the time and the skill tbh
