this westfield SEIW is like new with 725 miles from new moted till april 22 i was going to keep the car and fit an st 170 engine and sell the kent 1600 to the escort boys but ive found a classic that ive been looking for a long time and this is now for sale i know its not the best time of year but it would give to new owner a chance to update to modern running gear (by selling the tasty crossflow ) over winter ready for summer
powder coted chassis
Front and rear suspension, plated
Chrome headlamps/ halogen units
Fully trimmed with correct Westfield instruments westfield sorts seats now fitted
Heater and vents
New full weather gear, hood and screens
5 Alleycats & Yokohama now fitted wi "7 superlites the allycats are included in sale
Rear disc brakes with Sierra Cosworth callipers
Terry Nightingale Hillclimb springs, rec’d for road use
Bendix pump, pressure regulator
5 speed type 9 gearbox
BDA clutch assembly, lightened/ balanced
1600 pushrod, 711M block
Bug valve head
Forged flat top pistons
Tuftrided crank, balanced, lightened rods, duplex, steel rocker gear
Piper 5 port dry sump sysem, shallow sump, remote oil filter, oil cooler.
Kent 244 and competition Aldon Automotive distributor matched to cam
New Lumenition electronic ignition
Twin 40 Dellorto carbs, K&N filters
Magard cast alloy twin linkage
Westfield stainless steel competition exhaust manifold and system, no cat.
New high ratio steering rack
Ford English 3:9 differential, new brakes, bearings, joints
Heater and vents
Bug valve head
