I know that alternator wiring can cause issues with aftermarket ECU's but I would appreciate some guidance.
The wiring on Wifey's Pop is in the planning stage. I intend to make up an engine loom and plug and socket it at the bulkhead. The main charging cable will not go in that loom but it would be useful if the other two could (can't remember what they are sitting here but its a Nippon Denso unit).
Would this cause any issues or do I need to make a separate "loom" of two cables?
Ta for any advice offered.
