joe90
Yorkshire and The Humber
Sept 24, 2021 9:40:40 GMT
Morning all, now I know it isn't retro at all but I just want to pick some brains, I want to know what sort of job it is to replace the exhaust manifold on a 2009 civic diesel, is it something that can be undertaken on the drive with a set of ramps and a jack and is it an ok job or a pain in the . Thanks Bryan
Sept 24, 2021 11:53:48 GMT
Take the engine cover off and see what the access is like. Old civics had that on the side of engine next to the slam panel. If that's the case it should be doable unless the fixings snap upon removal.
Sept 27, 2021 13:05:13 GMT
If it's on the front of the engine do that thing where you take off more than you have to.
I worked as a mechanic for 7 years and it's one of those things you learn.
Even if it seems a bit mad to take off unrelated components you're thankful for the access later on.
If it's on the front of the engine take off the bumper and the radiators and get yourself some nice straight forward access. That way, when it comes to checking the mounting surface on the head and access for all the tools it is totally straight forward. Also wiggling an awkward shaped manifold in and out a small gap at the bottom of the engine bay can be a nightmare.
Sept 27, 2021 18:13:47 GMT
It's on the back of the engine and pretty well buried, not a job I'd relish on my back and I used to work on marine diesels.
Sept 28, 2021 8:52:21 GMT
It's on the back of the engine and pretty well buried, not a job I'd relish on my back and I used to work on marine diesels. I don't know exactly which model it is but googling 2009 civic diesel shows them at the front?
Sept 28, 2021 8:59:32 GMT
That looks like the 1.7cdti not the 2.2
Sept 28, 2021 12:44:58 GMT
2.2 definitely on the back.
joe90
Thanks for the info, it's not that bad and is barely audible when the engines running so I think I'll leave it until it fails an mot or gets really bad because I don't really fancy rolling round on my back changing it.
Bryan
you wont be on your back to change it! engine out job.
definitely a cracked manifold and not a leaking egr tube or gasket?
