Sept 13, 2021 19:33:54 GMT
In bright sunlight the top of my dashboard reflects in the windscreen - I was set to paint it mat-black but was advised that people who rally deal with the problem by using a custom made covering which can be trimmed to size/shape and doesn't have to be permanently fixed. Does anyone know of such a product? and where to get it? Advice appreciated . . .
Dashboard reflectionballbagbagins
@ballbagbagins
Club Retro Rides Member 164
Sept 13, 2021 20:06:28 GMT
You can flock your dashboard but a simpler solution would be to lay a piece of fabric on top of it.
Buy some alcantara from ebay.
Sept 13, 2021 22:15:35 GMT
You can flock your dashboard but a simpler solution would be to lay a piece of fabric on top of it. Buy some alcantara from ebay. Alcantara - never heard of it, so did some searching - can see that this will do the job really well. Many thanks BallBag
Sept 14, 2021 11:33:16 GMT
Mmm, an alcantara ball bag.
Sept 14, 2021 12:36:04 GMT
Mmm, an alcantara ball bag. Already got one, thanks!
Sept 14, 2021 16:15:39 GMT
Depending on which car You can try ebay.com.
Especially in the southern states dashboards often suffer from massive sunlight cracking, so lots of "carpetry" is offered over there for various models.
Sept 14, 2021 16:24:27 GMT
Depending on which car You can try ebay.com. Especially in the southern states dashboards often suffer from massive sunlight cracking, so lots of "carpetry" is offered over there for various models. If it's a RHD car, dashmats are also available in Australia, might be worth a try
vulgalour
Club RR Member Number: 146
Dashboard reflectionvulgalour
@vulgalour
Club Retro Rides Member 146
Sept 14, 2021 18:00:00 GMT
Speaker felt/cloth does the trick too, some is even sticky-backed if you want to stick it to the dash rather than tuck the edges in or similar.
Sept 17, 2021 12:08:41 GMT
Polarised sunnies. Can be had pretty cheap. Cuts the vast majority of reflections of any kind due to the way light organises itself when reflecting. Great for cutting glare from sun on a wet road too. Best 'mod' I ever made to my Nissan.
Sept 24, 2021 5:37:21 GMT
Previous owner of my R53 covered the top section of the dash with alcantara. Does a good job of stopping glare/reflections although the glue has started to lift in a few places now so will need to be redone at some point.
Last Edit: Sept 24, 2021 5:38:19 GMT by mattbee
