1991 Vw golf gti 2.0 16v(originally 90 spec 8 valve) solid black 5 door.
Engine 1996 ABF 2.0 16 valve
Gearbox standard mk2 gti 020 with weighted mk3 linkage and quick shift.
Standard mk2 gti 16v exhaust
Standard abf ecu engine management
Suspension Koni yellow adjustable dampers
Eibach springs
Eibach rear anti roll bar
Wide track via mk3 lower wishbones
Stub axle spacers on rear beam
5 stud hubs
280 mm front discs with mk3 16v callipers
Mk4 golf gti rear calliper conversion
Mk3 golf gti steering rack
Yellow poly bushed rear axle and front wishbones
15” bbs solitude alloy wheels
Avon ZV7 tyres
Mk3 golf gti fuel tank with internal fuel pump.
Standard interior trim and seats
Momo steering wheel
Auxiliary oil pressure and oil temperature gauges in centre console.
160 mph / 8k rpm speedo
Radio cassette player
Leather gear gaitor with mk3 anniversary gear knob
Standard 90 spec cloth interior in good condition, drivers bolster replaced.
Remote control central locking and alarm
Headlining ok.
Structurally in excellent condition.
Rear panel behind bumper replaced
Windscreen lower metal frame repaired
Fuel flap surround rebuilt and fuel tank support brackets reinforced and repaired
Minor repair to fr/offside jacking point
Cam belt replaced last year
Oil / filter changed annually and last month most recently
Recent new battery and starter motor
Mot until August 2022
Mot advisory work completed including replacement of n/s outer cv boot, oil cooler seal and rear wheel bearing.
Huge collection of receipts
I have owned this car for 8 years and it has been used and enjoyed at weekends only. I converted the engine myself quite soon after buying the car and over the years I have completed many repairs and improvements. The car has been extremely reliable and fun to drive to the point it has been driven to Scotland amongst other destinations.
The speedo pod was replaced at the time of the engine conversion so the car has a high mileage but the engine had only 115k at the time of installation, pretty much everything mechanical has either been replaced or improved over the years. Gearbox was retained as the rod change 020 as the mk3 box felt horrible in comparison, this 020 has none of the 2nd gear crunch or whines.
Bodywork is ok but showing 30 years worth of patina . It was built primarily to be driven and enjoyed but now it’s time for someone else to enjoy it.
077182 18970 for further details
Eibach springs
5 stud hubs
Avon ZV7 tyres
Momo steering wheel
Headlining ok.
