Sept 5, 2021 10:10:21 GMT
Hi all,
Getting all the electrical bits together for the wiring part of our VW T25 rebuild and would like hubby to install dashcams. One front, one rear.
Anyone got any good or bad experiences? Any recommendations? Ones to avoid?
Money not an issue for the right product.
TIA x
lilbob
Sept 5, 2021 19:12:21 GMT
All the dash cams I've used (work vans and trucks plus my own personal dash cam) Have been nextbase all are easy to use and pretty much the same layout
My only advice is remember to format the SD card regularly to stop it from corrupting
fulvia1436
Finally started a thread for my Fulvia life
Club RR Member Number: 63
'59 Austin A40, '59 VW Beetle, '63 Mk1 Cortina, '57 Austin Gypsy, '68 Fiat 850 Coupe, '68 Alfa Duetto Spider, '72 Lancia Fulvia 1.3S, '73 Lancia 2000 Sedan ie., '72 Lancia 2000 Sedan, '67 Lancia Fulvia 1.3, '83 VW Passat GL5 Estate, '81 Volvo 245 Estate, '85 Lancia Thema 8V Turbo Estate, '99 Lancia Kappa 20V Turbo Estate, '00 VW Sharan VR6, '06 Fiat Multipla 1.9 JTD, '10 Fiat Multipla 1.9 JTD, '66 Lancia Fulvia 1.3
Sept 8, 2021 19:49:40 GMT
Thank you 😊
Sept 19, 2021 21:23:25 GMT
All the dash cams I've used (work vans and trucks plus my own personal dash cam) Have been nextbase all are easy to use and pretty much the same layout My only advice is remember to format the SD card regularly to stop it from corrupting That's interesting, as my old SD card got corrupted, so with the new one if I regularly format it there's a chance it may last longer? I had just put it down to extreme temps etc.
lilbob
Sept 20, 2021 20:39:58 GMT
I do mine every 6 weeks or so
