A friend is building this replica car.
Powered by a late Series 3 Jaguar 4.2 engine.
Steering pump seems to have a problem, making noises when under load, even moderate load.
It is matched to a Senator 3.0 steering box.
Jag pump
Senator steering box
Youtube and Gogle suggested that there is air in the system and how to purge itβ¦β¦. Turn 4x to the left and 4x to the right, open breather and purge air.
Kevin has gone through the cycle repeatedly, to the extent of topping up at least a litre of PS fluid.
And still no resolution.
He seems to think the pump may have been run dry when he got and bench tested the motor.
QUESTIONS
1.) Could the pump be damaged?
2.) Can it be repaired?
3.) Can a replacement be found- A: Cheaply B: Free for price of shipping or collection?
I know a few guys on here dabble or are heavily into Jaguars and related products like ivanhoew and others.
If you are a power steering pump specialist or onow these things really well, please PM me so that I can connect you and Kevin.
Most of us probably use Whatsapp video or some similar system so it could be hugely helpful.
Thanks.
Jag pump
QUESTIONS
Thanks.
