After further inspection on what started as a suspected leak from the drive shaft seal - I now believe this is more likely to be coming from or rather falling from the brake booster/servo.
Looking at the state of it, the underside is pretty much melting from the liquid that has been dripping from it.
I think this means that both the brake booster/servo will need replacing and the master cyclinder which I understand from searching older threads is likely to be the real culprit of the two if there is liquid coming out? Maybe someone can confirm that for me or what I should be inspecting on the master cylinder to see if there is anything wrong with it.
The brake booster does not need inspecting, this is well and truly unhealthy whether it is operational or not, I would suggest that it is still operational as I read that it would hiss if faulty due to vacuum failure and the brake pedal would be unreasonably stiff which it is not doing either of these.
In any case at the moment I am looking to replace both the master cyclnder and the brake booster/servo.
I have the part number for the brake booster/servo: FINIS = 1629400 - PART NO = 84FB 2005B2 B
I have a link to all the components that make up the brake master cylinder : www.fordopedia.org/parts-catalog/fiesta-mk1/E1.10
So far I have not had any luck finding these components new or in great condition second hand.
Is there a retrofit option that will just bolt in that anyone knows of?
Thanks
Thanks
