Drove home, probably about 20 miles, last half mile the revs are sitting at 1000 to 1100, simple cable operated throttle on the 2.5 non turbo diesel engine, when i force the cable and bracket forwards (towards the front of the truck) the revs die a bit but i let go and it goes back up again, i switched off, gave it 30 seconds, then fired up again, and it idled perfectly? all parts are lubricated regularly, there does not seem to be anything too complicated with the set up...? any ideas?
The annoying thing is that it's just had new rear bearings, wheel cylinders leaf spring and shakles and brake shoes! curse word all to do with the other end!!!!!
