At some point soon I'm going to need to do some carb jetting.
New ground for me this, and I've no clue about afr gauges, but thought one might help.
Had a look and they seem to mostly be quite expensive but with the usual cheap Chinese stuff also available.
Are cheapos any good?
Will be for sorting the jetting on a 1950s amal carb so we're not talking highly accurate mixture setting.
I have a spare header I can put a lambda sensor in, I assume that and power are all that's needed?
