Oct 20, 2021 10:17:14 GMT
Save you painting it mate the grill inserts release from the surrounds, so you can use your colour surround with the V grill Also all back boxes are the the same fitment apart from the 1.6 8v, from 1.8 to 2.6 Cheers mate but anoyingly the Aus-spec Holden grille has a completely different fixing arrangement to the 'V' grille - the former is just clipped together and the latter is plastic welded in completely different places Whilst I think the back boxes from other engines will fit, the 2.5 has a twin tailpipe arrangement whereas the smaller engines don't. I like the look of the twins, even if it is just pointless aesthetics...
Oct 20, 2021 20:16:41 GMT
those manuals are a great find, if they are anything like the calibra ones i have, insanely detailed
those manuals are a great find, if they are anything like the calibra ones i have, insanely detailed Yeah they've been a great help so far - especially the X25XE volume as so much of that info just doesn't exist anywhere else. From what I read online a lot of V6 owners are a bit scared to DIY too much in the way of engine work - having in-context step by step instructions and the correct tools makes stuff a lot less scary. I wish there was an easy way to scan the whole thing and put it on one of the owners forums but it's quite a chunky thing so would take me quite a while to do it.
Last Edit: Oct 21, 2021 0:17:56 GMT by llessur
A couple of minor updates on the Vectra. I surgically removed the old giffer spec warning klaxons that had been wired in to the indicator circuits and made the car sound like the cockpit of a crashing Boeing 747 every time I was waiting at a junction: I also replaced the tatty old handbrake gaiter... ...with a pleathery eBay special... Somewhat annoyingly I also managed to crack the plastic brake light on the spoiler when changing out a couple of the blown bulbs. It's an ICC spoiler with a Hella light unit just in case anyone reading this has one lying around. Otherwise I'll just have to keep an eye out at the breakers and hope one comes up: The cracked piece is underneath so it's not that obvious unless you're kneeling down and looking up at it but it was in perfect condition until my fat fingers ruined it Other than that I took it for a 25km drive, some of which was on the motorway, and it drove really nicely. Whilst I'm sure it's not the hottest of hatches, it is by the far the quickest car I've ever had and is tremendous fun for someone like me who's only used to driving 70s Triumphs and bland Japanese SUVs until now
Last Edit: Oct 22, 2021 4:11:08 GMT by llessur
Oct 26, 2021 13:52:22 GMT
my only experience of the big 6 was in phase1 gsi, it was quite fun car to drive, seemed to pull strongly at most revs and a pleasing grumble even with the stock exhaust. it was terrible on fuel though, although as you say compared to the 1970s you do get a better return for your terrible mpg
I finally found the time to give the Vectra a wax, and to treat the black plastic trim to some surprisingly pleasant-smelling Autoglym bumper gel. Scrubbed up pretty nicely for an old girl! Next step is to give the interior a vacuum and a clean and to install the NOS mats I picked up. It's pretty good overall but there's a few makeup marks from the previous owner which need to be cleaned off. I've also got a NOS seatbelt to fit as the driver's one doesn't retract very well. Looking at the belt I think it's a makeup-related problem as it's pretty caked in what appears to be heavy foundation (I'm no makeup expert though) and has made the belt a lot stiffer than it should be. I've got it working a bit smoother after giving it a good clean but it's still not great so replacing it is the easiest course of action - I'm not that keen on a breakers yard special of unknown provenance. The replacement sump seal has also arrived so I'll pluck up the courage to tackle that at some point. I'm not too worried about the sump part of the job, I just don't want to strip any manifold bolts when I remove the downpipes as that'll be a right nightmare to sort out given the very limited access to them...
Nov 26, 2021 13:24:59 GMT
Wax furniture polish is good on seatbelts to lube them up a bit, my Astras get a bit sticky now and then. Love this though, I looked for another one recently (would be my 14th ) and they seem near extinct here now.
Have just bought a new radiator for the Veccy as the existing one is leaking - I should have sorted it earlier but I've been trying (and failing) to build up the enthusiasm to spend a whole day of my life stripping down the entire front end just to fit it... Once it's done however it should be fairly finished on the mechanical front, other than the oil leak from the oil level sensor. We've got family coming over to visit for a few weeks at Easter so it will be pushed into daily service for a while so I want it to be pretty much sorted by then.
Last Edit: Feb 8, 2022 5:28:05 GMT by llessur
Pulling a bumper on a Vectra B is a job I hated, torx bolts behind the wheel arch liner with a fine thread and 2 inches long, take forever to come out and chew your hands to pieces. Don't blame you putting it off
The impending arrival of family from the UK meant I finally had to pull my finger out and attack the leaky radiator on the Veccy. A job that I'd been putting off for as long as possible - not because it was particularly difficult but because of the crammed nature of the V6's engine bay it, like most other jobs at the front of the car, required a significant amount of stripping down just to gain access. Spoiler alert - here's a work in progress pic from mid-change: I've owned a lot of 'pre-loved' (read: pre-scrapyard) cars in my time and have changed my fair share of radiators but the Vectra wins hands down for the biggest number of un-related components I've ever had to remove in order to complete the task. Here's a reminder of just how tight things are in that general area: There are various different methods of attacking the job banded around on forums etc but seeing as I have access to the factory manuals I decided to take the recommended approach of removing the rad from above. Another method is to remove from the front after swinging the AC condensor out of the way but I'm loath to put too much strain on 20+ year old AC components given that a functioning AC system is pretty important out here and the one on the Veccy currently works well. The first step is to remove the battery and the front intake plenum (the easier of the two plenums luckily), followed by the front bumper and grille. I've got the front bumper removal down to a fine art now - by unclipping the very front edge of the wheel arch liners I can just about get my hand and a small spanner through the gap to undo the fixings. Saves faffing around with removing the arch liners completely, athough it comes at the expense of slightly shredded hands. Next comes a whole heap of disconnections - power steering reservoir, top radiator hoses, multi plugs for the secondary coolant pump, AC system, cooling fan etc and being an auto the transmission fluid cooler pipes too (luckily there are quick-release connections at the mid point of the hoses so a pretty easy task). With respect to the latter I made sure to give the connectors a good clean before uncoupling and wrapped both ends of the pipes in plastic to prevent any dirt getting into the transmission. At this stage the radiator fan housing complete with secondary coolant pump etc can be carefully liberated upwards from the engine bay: Things get a little easier at this point as without the fan assembly there's something approaching a viable amount of room for someone with human-sized hands to work. The bottom hoses and fixings can now be disconnected and the radiator removed upwards and outwards. Here's the offending article: I couldn't see any obvious holes or damage, it just appeared to have a small leak around one of the seams. Still, I've had small leaks turn big quite quickly in the past so it had to go regardless. Before it went to its new home in the bin I swapped the thermo switches, AC cooler pipes and mounting hardware on to the replacement rad: Replacement was the reverse of the removal - although I took a bit more care not to damage the fins than I did during disassembly. After everything was buttoned back up I refilled the cooling and ran up to temperature to bleed it and check for leaks. I'd already replaced the transmission fluid with the same volume which was lost during the radiator change, but I fine tuned this over the next few drives when the transmission was up to temperature. Once it was roadworthy I had four new Kuhmo tyres fitted to replace the 11 year old but virtually unworn set of Kuhmos it came with. A bit of a shame but I don't like the idea of running around on very old rubber. So far so good - we used the Veccy almost daily when the family were with us, including for a 100 mile round trip to Port Elliot south of Adelaide and it didn't miss a beat. Other than the trademark rock-hard seats it was a joy to drive. The last remaining job is to address the leak from the oil level sensor. Whilst this is just down to a simple o-ring, replacement requires the sump to come off (and therefore opens the possibility of shearing manifold studs etc) so I'm reluctant to do anything about this right now. Next time I've got the oil drained for a change I'll stick a smear of sealant around the outside of the sensor and try to keep it at bay that way. If it gets worse I'll have to bite the bullet and change it out but I've got bigger fish to fry with other projects so I can live with it for now.
Last Edit: May 18, 2022 3:40:30 GMT by llessur
Have recently moved offices to one with a multistorey car park next door so have temporarily ditched the train and used the Veccy to commute for the last couple of days. I've filled the CD changer with various albums from the 90s/00s and it's been a blast I also raided the box of random stuff that's followed me around the world and dug out the leather keyring I bought an increasingly disturbingly long time ago (1997) after I passed my driving test and celebrated by procuring a 'lovely little motor' - a white C reg Vauxhall Astra. Not quite the right model obviously but it's close enough. I remember when these leather keyrings with car logos were absolutely everywhere back in the day but it's virtually impossible to find them now. I'll keep an eye out on eBay etc for a Veccy one but I quite like the thought that this has been brought back into service after 25 years in a cupboard!
Last Edit: May 20, 2022 4:50:28 GMT by llessur
Going back to the post about wheels on page 1, the ones you pictured are sri wheels, These are the ones you need, the star ones are ph1 gsi and the second ph2 gsi.
May 20, 2022 13:40:27 GMT
Going back to the post about wheels on page 1, the ones you pictured are sri wheels, These are the ones you need, the star ones are ph1 gsi and the second ph2 gsi. Oops, my mistake. It's definitely the SRi wheels I'm after. I've since found they did actually use them on a limited number of Vectra 'International' cars out here - they had leather, those alloys anda few other toys. Hopefully this means I'll eventually be able to pick up a set locally 🤞
May 24, 2022 10:16:22 GMT
astra keyring is weird, its 70s early 80s griffin on a 1990+ roundel. probably aftermarket (there used to be a halfords-esque chain store in uk called charlie browns that had aisles and aisles of car/brand specific stuff like this)
May 24, 2022 23:58:41 GMT
astra keyring is weird, its 70s early 80s griffin on a 1990+ roundel. probably aftermarket (there used to be a halfords-esque chain store in uk called charlie browns that had aisles and aisles of car/brand specific stuff like this) I can't for the life of me remember where I got it from but it was pre-eBay (or at least pre-me using eBay) so it was most likely Halfords. I'm not sure we had a Charlie Browns in my neck of the woods (just north of Brighton) but my second guess would have been an independent motor factors I used to use - VKM in Burgess Hill.
astra keyring is weird, its 70s early 80s griffin on a 1990+ roundel. probably aftermarket (there used to be a halfords-esque chain store in uk called charlie browns that had aisles and aisles of car/brand specific stuff like this) I can't for the life of me remember where I got it from but it was pre-eBay (or at least pre-me using eBay) so it was most likely Halfords. I'm not sure we had a Charlie Browns in my neck of the woods (just north of Brighton) but my second guess would have been an independent motor factors I used to use - VKM in Burgess Hill. And on that subject - I was lucky enough to fit in a trip back to the UK in early 2020 before the COVID struck and sadly noticed that VKM has closed and is now a tyre fitting place. It's a real shame, it was a proper old school place which had been there for 40-odd years, the staff knew everything and there was nothing they couldn't get (and usually within a day if they didn't have it in stock already). It seems the local independent motor factors is becoming an increasingly rare species these days I think the situation is similar here in Oz but I'm lucky to have a great example just down the road from me in the form of Ian Jones Auto Parts: A visit is like stepping back in time 20 years - two blokes behind a counter, both smoking, shelves full of random 80s car accessories in yellowing packets, the counter's covered with tins of random o-rings, paper parts catalogues etc. Everything a motor factors should be. Service is great - if they haven't got it they can get in quickly and their prices are pretty reasonable to boot. I hope it stays open for many years to come.
Last Edit: May 28, 2022 6:53:51 GMT by llessur
May 27, 2022 10:21:49 GMT
man, there used to be an alternator/generator repair shop in chatham, just a diminutive little row of shops built into the base of 1960s flats. smelt like imperial war museum and like you say they just so good at their job its a very comforting experience
Sept 16, 2022 2:55:21 GMT
Still going strong and being used regularly for the commute
Aug 31, 2023 13:35:13 GMT
Had a bit of a scare and thought for a while the Veccy's days might have been numbered - overnight the car started to leave an alarming puddle of power steering fluid on the driveway and the level went down to the minimum mark on the reservoir dipstick. My first thoughts were that the steering rack seals had gone and because I've got so much to do at the moment, dropping the front subframe to change the rack was not going to be a job that I was even going to consider putting on my to-do list. So I'd mentally prepared to either scrap it or sell it dirt cheap and, quite excitedly to be honest, started browsing for XJ Cherokees online (another itch I really want to scratch). However, I found some time today to stick it up on the ramps and had a bit of a prod around and luckily for the Vectra (not so much for my Jeep ownership dreams) it turns out that the leak was due to a banjo bolt attaching one of the hydraulic lines to the rack working loose. That's this little fella in case you're not familiar with these bad boys: Like everything else on the V6 Vectra it's a right pig to get at - partially hidden by a heat shield and almost hard up against the AC drain. I must have spent close to an hour under the car trying to contort my arms and wrists into a suitable shape to get something - anything - onto it to tighten it up. In the end, after working my way through various sockets, spanners and adult words, I managed to nip it up with an adjustable wrench. The leak appears to have been solved for now but ideally I need to invest in a stubby 21" (or 22" - I still didn't quite manage to figure it out) ratchet spanner - if such a tool exists. There's also another smaller power steering fluid leak from the bottom of the reservoir. I can't quite figure out what's going on here - I've tightened the jubilee clip for the hose as much as I dare but it's still dripping occasionally. I'm starting to wonder if the plastic reservoir has a hairline crack so I'll keep an eye on it. In other news, the driver's side indicators gave up the ghost on the way to work last week. A quick trip to the local breakers and a new relay robbed from a Saab 9-3 solved that little problem: I also need to think about fixing the slow drip of coolant from the plastic joiner for one of the heater lines. It's got one of the GM quick release clips on it and I think these have a reputation for causing problems so, combined with the fact that a replacement OE pipe is unavailable, I might have to have a think about replacing this connection with a standard joiner. The only other thing I've done on the car recently is to finally get round to fitting the replacement new old stock driver's seatbelt I managed to pick up - the old one was fairly slow to retract, partially because I think it was so gummed up from the previous old lady owner's makeup. (New left, old right)That was a pretty easy job of removing the B pillar trim: And then undoing the bolt holding the belt mechanism to the B pillar via the convenient access hole: Then attaching the new belt reel: And then threading the belt up the B pillar and fixing the top mount and the mount on the base of the driver's seat: The new belt's much better - it's amazing the difference these little fixes make to the overall feel of the car. Other than those little problems it's really been faultless over the last few months, hence the lack of posts. I did find a nice '98 Vectra CD at the breakers, but it wasn't a V6. However there are a few bits and bobs which I might go back and grab at some point. I'll update this thread if I do.
Last Edit: Aug 31, 2023 13:37:40 GMT by llessur
Aug 31, 2023 16:17:14 GMT
Is it this hose your after? if you can get the part numbers ill check over here for you
