madmog
Club RR Member Number: 46
Jul 23, 2021 18:13:09 GMT
I can see how and coil pack for a 6 cylinder engine is just 3 x 2 wasted spark coils stuck together. In terms of neatness of fitting, 3 x 2 coilpacks could work well in my application but I can't find 2 cylinder coils that aren't expensive. Is there anything from the motorbike world or elsewhere that are up to the job and reasonably priced?
Taking the next logical step, how easy is it to make two coilover plugs act like one coilpack wasted spark coilpack?
Also, on a straight 6 engine, firing order 153624, which cylinders should fire together please?
Thanks
Last Edit: Jul 23, 2021 18:14:16 GMT by madmog
Jul 23, 2021 18:29:19 GMT
any good
Jul 23, 2021 18:37:39 GMT
None of the cylinders will fire together so to speak, however 1&6, 2&5 and 3&4 are in the same position at all times.
madmog
Jul 23, 2021 20:57:00 GMT
any good Brill thanks
madmog
Jul 23, 2021 21:00:52 GMT
None of the cylinders will fire together so to speak, however 1&6, 2&5 and 3&4 are in the same position at all times. Ah, not fire, 'spark'. Should the aforementioned pairings spark togeher, one cylinder getting the wasted spark?
Jul 23, 2021 21:22:23 GMT
Yes the pairings will have one fire and one wasted spark.
Not sure if they’re suitable for your application, but the later Rover K series engines have 2 cylinder coil packs,mounted on top of one plug, with a lead to another, ie 2&4, 1&3
Taking the next logical step, how easy is it to make two coilover plugs act like one coilpack wasted spark coilpack? Thanks I spoke to Canems about this a while ago. It's easy to do but must be 4 pin (built in ignitors) and may need firmware mods depending on the ECU. Haven't done it yet so I know no more.
madmog
Jul 27, 2021 14:05:59 GMT
Thanks dickie12, xbl, comfortablynumb & crockpot. I think the Renault ones might be the answer. The k series - well the distancing would be too great. I don't really want to extend the ignition wires.
Jul 27, 2021 20:56:13 GMT
madmog
Jul 29, 2021 11:28:49 GMT
Thanks Rascalti, This raises some new questions. This coilpack replaces the EDIS module with its built in amplifier so could be cost-effective. The latest Megajolt from Autosportlabs allows you to add an ignition amplifier as part of the purchase. Ie. trigger-wheels.com/store/contents/en-uk/d63.htmlPresumably instead of the EDIS. I'm trying to understand if there is a wiring difference between EDIS and 'dumb' amplifier either built into the coil or as a standalone amplifier. Looking at the MJ diagrams, with EDIS, both the MJ and EDIS receive the signal from the trigger wheel. In the absence of any other input from MJ, the EDIS will fire at 10deg BTDC. With an ignition amplifier, in the absence of MJ, does it default to anything as per EDIS or just do nothing? EDITED FOR NEW INFORMATION Just received a reply from AutosportLabs/Megajolt 'You must use an EDIS module, you can't use an ignition amplifier'. So the coilpack with ignition amplifier shouldn't be used. A dumb coilpack should be used instead. In my case a dumb 6 cylinder coilpack or 3 x 2 as per Dickie12's Renault suggestion above.
Last Edit: Jul 29, 2021 11:50:28 GMT by madmog
