Jul 24, 2021 21:00:50 GMT
kevinsPlease could you dumb down the test for the thermostat for me. I think you are saying take the plug off the sensor which is likely plugged into the thermostat housing, turn the ignition on and place some metal over the two pins? I don’t play around with electrical bits often!
Last Edit: Jul 24, 2021 21:01:57 GMT by k11ngsley
Jul 24, 2021 21:02:30 GMT
If it’s one pin then just place a wire from the connector to bare metal?
to test the electric fan remove the plug from the thermostat housing use a paper clip to join the connection then turn on the ignition and the fan should run and the fan won't come on until the gauge is almost in the red
Perfect. Thank you and thank you.
Paper clip test first and then temperature test second.
Will report back when complete.
Jul 27, 2021 10:29:26 GMT
it’s part of the cooling system and is bolted onto the front (side facing out towards the headlights) of the engine. That is the front water rail, i think there are differences between mk1 and mk2 fiestas, so make sure you get the right one Because of the fwd installation, it carries water from the pump under the exhaust 👍
Jul 27, 2021 20:08:41 GMT
Thank you. I have got the part number now.
At the moment can only find for the MK1
Part number: 84FB8274AB
Jul 27, 2021 20:23:52 GMT
Jul 27, 2021 21:08:03 GMT
