Montana paint prep on wingsballbagbagins
@ballbagbagins
Club Retro Rides Member 164
Hi, i have two brand new wings to fit in place of rusty ones.
I don't have the money to get them sprayed by a bodyshop and all spray painting of bodywork I've ever done has turned out poop.
So, I was thinking of spraying them in non-body coloured Montana spray paint.
How would I prep the wings and would I need a clear over the top of the colour?
Pete
Rich
Club RR Member Number: 160
Montana paint prep on wingsRich
@foxmcintyre
Club Retro Rides Member 160
Hi, i have two brand new wings to fit in place of rusty ones. I don't have the money to get them sprayed by a bodyshop and all spray painting of bodywork I've ever done has turned out poop. So, I was thinking of spraying them in non-body coloured Montana spray paint. How would I prep the wings and would I need a clear over the top of the colour? Pete A good base primer, something like Buzzweld RE would be ideal. No clear is required on Montana. ‘Black’ is the satin range, ‘white’ is gloss.
jgtr
Key with red scotch or 320-400, epoxy primer and Montana over the top?
Thread resurrection to ask the experienced among You:
Since Montana (white in this case) is actually graffiti paint: how long does it take to dry on a car, outside in sunny weather?
Rich
@foxmcintyre
Thread resurrection to ask the experienced among You: Since Montana (white in this case) is actually graffiti paint: how long does it take to dry on a car, outside in sunny weather? Not long. Quick enough to make painting a car in one hit hard enough with a dusty edge on adjacent panels. Will take a few days to fully cure but it dries off quickly.
Thanks Rich, I have some spare doors and tailgate that I will paint separately in-&outside, but before I put them on the car, I want to paint the hidden areas, too, and put the parts on the same day.
Montana paint prep on wingsstealthstylz
@stealthstylz
Club Retro Rides Member 174
When I get time to do silly paint jobs it's safe to mask over Montana after half an hour if its a reasonably warm day.
That sounds good, thanks.
