This blast cabinet was one of the DIY plywood kits that Frost Restoration used to sell. It's been nicely built. Not by me, I must add. There's no way I would do such a tidy job of it. Although I've since fitted a flood light inside, new gloves and some wheels so it's easy to move ouside. It comes with a half full tub of Al oxide grit and a full tub of glass beads and a Hetty vacuum for dust extraction. It's just about big enough to get a wheel in and have room to work.
Be warned though - you'll need a beefy compressor to run this. I had a 5HP/100l compressor and it could only just cope with the light blasting of alloy castings that I was using it for. For rusty steel you are going to need something a lot more powerful.
£100 for the lot. I'm not far from Warwick/Solihull.
